Aston Martin DBR-9 2005 Le Mans
will69
153
307
41
Sweden, Scandinavia
Due to some technical issue my build-thread of the Aston Martin has driftet of in the darkness of cyber-space :eek::cool:;);)
so I have to start all over. I have all pictures on my HD so here we go...
First of is the presentation. This is what I am building. It was intended for A4 but I enlarged it to A3, hopefully I dont get any fittingproblems.
/Wilhelm
9,549
Will, I am so sorry about that. I was following your thread. I did an extensive search and it is gone. It may have been deleted when we were hacked, as some threads were lost, it lost a fortune to recover the data. I can tell you I am very happy you are posting the build again, this is a great model, and your build thread is excellent. Thank You for reposting.
It helps other so much to see any problems uncovered and the technique you have used to decipher any poorly, or vague instructions. ;)
Reactions: will69
will69
153
307
41
Sweden, Scandinavia
Thank you. Zathros. Thank for a quick answer when I asked a while back. That´s what I like with this forum. All the people helping eachother. thumbsupthumbsup
And on we go with the interior
The steeringwheel , dashboard and databoxes. I laminated the steeringwheel to get a 3D-effect.
20170309_142053721_iOS.jpg 20170318_180222036_iOS.jpg 20170318_181229912_iOS.jpg
The dashboard and databoxes. The gearstick is also laminated, the result you see in the pictures above.
9,892
I would lie to echo Zathros in apologizing for the loss of this thread. we did loose quite a bit. I am glad that you still have the original photos and are reposting this thread.
I have to say that the detail that you are putting into this model is SPECTACULAR!
THANK YOU once again for reposting this!!!
Reactions: zathros and will69
9,549
You have done a fantastic job. When you can post a picture that big, and the model still looks excellent, what more can be said. :)
will69
153
307
41
Sweden, Scandinavia
Welcome to the wheel-factory thumbsupthumbsup
The wheel-knobs, made of rolled paper and toothpick. I should have put a ruler for comparison, but i forgot...:):)
The spokes and inner-rims, the spokes needs to be bent in a special way to get the curve, hopefully the pictures shows that. :)
Finished set of wheels. I hade to cut the outer rings of the wheel to be able to bend them properly.
This is how far I have come in the build. :wave:
Wilhelm
9,549
You're into the hard part and succeeding!! I have been using Liquid Electrical Tape for wheels, it works great, and you can build it up with a normal paint brush. Looks like a real wheel. works excellently on electronics, and waterproofing the back of switches, like the ones over our half a dozen aquariums.
9,549
I believe this is the nicest build of this model I have ever seen. Superb craftsmanship. It's a pleasure to see the progression. :)
