ask about Metasequoia
Discussion in 'Tutorials' started by seawolf, Aug 25, 2005.
  1. seawolf
    seawolf Member
    hi all,
    first of all I would like to apologize if this topic is not place in the right place.
    I have a question regarding Metasequoia.
    does this engine have a feature to 'trim' a 3D shapes?
    let say I want to have a sphere with a hole with cube shape.
    the idea is to create a sphere then trim it with cube shape.
    thanks in advance.
    Fiat
  2. seawolf
    seawolf Member
    hi all,
    thanks in advance.
    Fiat
  3. NOBI
    NOBI Active Member
    Hi Seawolf,
    it is easy if you want to Trim with a flat shape like cube, just use a knife to cut it out :)
    but for different shape trim, you must have a plugin what can do this job for you...plugin will available in registration only.
    let's me demonstrate
    first i have cube
    [​IMG]
    and a circle or sphere you want
    [​IMG]
    and cube with sphere
    [​IMG]
    use plugin "Boolean" what is a default plugin from standard registrer version, menu is in japanese but my system cant display that
    [​IMG]
    new window apeear and choose option like below
    [​IMG]
    after click OK...new opject appear with result you want
    [​IMG]
    [​IMG]
    easy? 1-2-click and you got result
    Another result
    [​IMG]
    [​IMG]
  4. NOBI
    NOBI Active Member
    Hi Seawolf,
    first i have cube
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Another result
    [​IMG]
    [​IMG]
  5. seawolf
    seawolf Member
    oh man, mine is not a registered version :(
    anyway to do it with knife?
    I know it will be a pain in the ###, but if it's possible to do it - I'll try it first :)
    I'm try to build a simple model of ID4's alien invasion ship. I can do fine with the basic cut out of the sphere, but at some point of the sphere, it has a sunken / concave shape space.
    anyway NOBI, thanks for the guide and information.
  6. seawolf
    seawolf Member
