Apollo CM & SM 1:24th Design/Build Thread
Discussion in 'Space & Aeronautics' started by Carl (Surfduke) Hewlett, Mar 16, 2007.
  1. MOS95B
    MOS95B Member
    Go check it out. I updated the site, and added the link to my sig.
    Whatcha think, Carl? It's actually your site in a way
  2. Bengt F
    Bengt F Active Member
    Moon Port New Web Design
    MOS95B,
    That´s somethin´ else! Looks very good! Carl must be proud.
    Bengt :D
  3. Bengt F
    Apollo Capsule Internal Bulkhead Formers
    Carl,
    As I was cutting out the internal formers on page 13 (parts nr 59), I realized that they probably would have to look something like this to correspond to the current heat shield and internal 'floor' or 'back wall' bulkhead, behind the astronauts seats:
    [​IMG]
    Of course the correct rounded shape would be desired, but it will require some more cutting work.
    Perhaps two versions of the formers - a round and a straight one? What´s your view on this?
    All the best,
    Bengt :D
  4. Carl (Surfduke) Hewlett
    Carl (Surfduke) Hewlett Active Member
    Hello
    The squared off version will be too stylized, (I think). I will look at it in the morning. I used the profile from the cross section. I will check it against the final shield contour, (and correct it).
    Thanks for the heads up.
    Talk to You in the morning.
    Carl
  5. Bengt F
    Apollo Command Module 1:24 Scale
    Hi all,
    I found this picture, which might help with the positioning of the interior parts (the seats are missing):
    [​IMG]
    Best of luck with your builds!
    Bengt :smile:
  6. Carl (Surfduke) Hewlett
    Cm Rev 8
    Rev. 8 has been sent for upload. I will be writting the rest instructions tonight. I will provide a black Chair Rail option, Blunt curved heat sheild, (4 part), & and a straight gray interior, (With more detail), after some Beta Build Feed back.
    Have a great day,
    Carl
  7. Carl (Surfduke) Hewlett
    Btw
    The Skylab paint scheme has been changed, (I was wrong, (The white does not go all the way around)). Thanks for pointing it out.
    See You later,
    Carl
  8. MOS95B
    MOS95B Member
    Half hour delay ain't bad, huh???
    Revision 8 has been uploaded.
    Come and get it!! :grin:
  9. Carl (Surfduke) Hewlett
    Nice Page Look!
    Thanks for the page Update! It looks cool to Me! The link is just what I envisioned.
    I am working on the CM, and the Pad 34, instructions now.
    Carl
  10. Amazyah
    Amazyah Senior Member
    Hey Carl, Rev 8 really looks great!
    Would it be possible to get a thin line put around part 27 on page 8?
    Can't see where to cut it out as it is so faint.
    Russell
  11. Carl (Surfduke) Hewlett
    No Problem!
    I will put a light line around it. I also need to put the rescue arrow back on the Skylab hatch, (Opps!). Hope the rest is looking up to snuff?
    Carl
  12. NULLMOON
    NULLMOON Member
    looking sweet how about an un-colored outer for anyone lucky to have the silver cardstock?
  13. Carl (Surfduke) Hewlett
    Ok
    I will post one in the morning, (unpainted). I know Dhanners will want it that way too. I have to do a wallsection, for a meeting in the morning. Then finish some instructions for this project. Got to go.
    Enjoy,
    Carl
  14. Amazyah
    Thanks Carl!
    It's really great to have a responsive designer right here, working right along with the builders to create something everyone will enjoy!8)
    Thanks for everything!
    Russell
  15. Carl (Surfduke) Hewlett
    You are welcome!
    I like this method! It seems to be working well for everyone.
    So Far, (Not So Bad, (LOL)),
    Carl
  16. Carl (Surfduke) Hewlett
    Fyi
    I will publish the instructions sometime tomorrow. I also saw a publish error in the pdf of the Skylab option, (Part 4 got overlapped by a glue tab part, (That should not be there). I will fix this and add the rescue arrow to the main hatch, (When I put out the instructions).
    Have a great night,
    Carl
  17. obiyan
    obiyan New Member
    new CM panel from nassp add-on developement for orbiter space flight simulator (not finished)
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  18. Bengt F
    Apollo CM Silver Chrome 'Skin'
    Hi all,
    I have looked at some 'silver' papers but most of the ones I´ve looked at are dull and gray and hasn´t got the proper 'shine' for the Apollo CM. Sadly, I can´t obtain the Red River Silver paper here in Sweden - I´ve been in contact with the company but they refuse to send it to Sweden.
    David Weeks has got it right on his resin model:
    [​IMG]
    I got the idea that I could try with thin strips of aluminium 2" duct tape. I think I´ll do that. I´ll post a pic if it turns out OK. It´s worth a try . . .
    Perhaps we should continue down and build the whole Saturn V in 1:24 scale, now that we have such a marvellous beginning? It would be roughly twice as big as this 1:48 scale one (which is a launchable plastic rocket with functioning F-1 model rocket engines):
    [​IMG]
    All the best,
    Bengt :smile:
  19. Hans Christian
    Hans Christian Active Member
    oh my... my hands are gonna bleed on a 1/24 Saturn V!!! :-D
  20. Carl (Surfduke) Hewlett
    Instructions are out
    Rev. 9 and instructions are in the hands of our Host! I have been looking at the Mylar tape pattern. At this scale the best method, (I see), is to publish a lite line version. Then the builder can print/plot on high gloss precolored paper. I will rework the interior with more detail, (and update as You guys find flaws, and new research stuff).
    Thanks,
    Carl
    I am going to work on the SM today.
