Apollo CM & SM 1:24th Design/Build Thread
Discussion in 'Space & Aeronautics' started by Carl (Surfduke) Hewlett, Mar 16, 2007.
  1. Mechanic
    Mechanic Member
    Heatshield
    WOW! This is looking so good, so quickley, I can't believe it! Carl, you do increadible work.
    I almost hate to make a suggestion, since I have no idea if this is too difficult to figure out the right dimensions/cut lines, but how about something like this:
  2. Carl (Surfduke) Hewlett
    Carl (Surfduke) Hewlett Active Member
    Right on!
    That should do the trick!
    Thanks,
    Carl
  3. Darwin
    Darwin Member
    Carl, do you think the piece might be stronger (less liable to tear into confetti) if the top and bottom "darts" were offset? (The two cuts not opposite each other)
  4. Carl (Surfduke) Hewlett
    Good Point
    Thanks for that idea.
    Have a great night!
    Carl
  5. Hans Christian
    Hans Christian Active Member
    Hmmm... How about the way sir ton noteboom did with the S-IC, the cap-like part of the fuel tank?
  6. Carl (Surfduke) Hewlett
    Thats a idea, But....
    Good idea for the bottom, (But the bull nose at the edge?). I will play with all these ideas after I get the interior finished. The Post Recovery Version, Will be up today. Fit trouble with the interior bulkhead, will push the first interior release, until tomorrow. I have a few questions on the fold points on the couches too, (Any drawings that are out there would be helpful). I was informed from a ex-padrat, (That lives close by), that the White skim coat on the Skylab & ASTP CM's was to reflect heat, (They had to station keep in shut-down, (for a long time, (Still learning new stuff, after all these years))). The one on display at the cape, (Saturn Center), was the standby rescue craft for Skylab. It has had the exterior cleaned, down to the shinny skin. The interior of that craft has the extra seats in the lower area. The display tunnel view window, does not allow a view of them, (But they are there).
    Just FYI stuff,
    Write and post more later,
    Carl
  7. milenio3
    milenio3 Active Member
    Thank you Carl for this design. It will certainly be a great part of the Real Space collection.
    Looking forward for more.
  8. Carl (Surfduke) Hewlett
    Fresh Meat!!!
    See attached file for all the exteriors. FYI, (The ASTP CM is Silver). The Resue Capsule for Skylab was 1/2 white, (Never flown, (I did not put this option in, (May add it later))). I am working on the interior & Tunnel now. I will try and work out the Heat shield tomorrow. BTW, on the interior, I am going to detail only the visable areas for now. Sometime in the future, (I may do a removable bulkhead version). I think the detail I have done so far, will reduce fine for those wanting a 1:48th version. I will do the LM next. Then We can address the Skylab interior.
    Enjoy,
    Carl
  9. Carl (Surfduke) Hewlett
    Rev4 is ready
    It is too big to post as one file. I have sent it to the admin. to see what He can do. The nav. widows have been fixed. The first of the interior parts is also included.
    Have a great night.
    Carl
  10. jparenti
    jparenti Member
    What kind of Skylab interior are you thinking of doing? Will it be seperable so you can see the seperate levels, like the stages on rocket models, or are you thinking of something else?
    I for one am really looking forward to the Apollo and Skylab interiors. Sometimes the outside just isn't enough! :grin:
  11. the mole
    the mole Member
    Another work of art Carl. Your a master at this stuff.
    I have a question. Are you going to have the escape tower for the Apollo capsule like T. Noteboom did for his Mercury capsule? I think that would look cool.
    We alway want more don't we.
    Thanks again.
    The Mole.
  12. Amazyah
    Amazyah Senior Member
    For those who are waiting for Carl's newest files, I will post them now in jpg format.
    The original file was a pdf but I don't know how to split one of those up so I converted each page to it's own jpg file at 300dpi.
    There are 8 pages to the file.
    Russell
  13. Amazyah
    These are the last 3 pages.
    Russell
  14. Carl (Surfduke) Hewlett
    I was thinking
    Skylab will need to have a full side panel, that can hinge, or remove.
    Carl
    P.S.
    The Admin. is going to post the newest files soon. I am still spraying pixels on the rest of the interior, & heat shield.
  15. Carl (Surfduke) Hewlett
    I will do the LES
    The LES will be a part of this project. That will be done after the interior. I need research material on the color of the side instrument duct, (connecting the CM to the SM). Some pictures show it white, silver, & black. I have published it as white. Also I need to know if We should do all the options for the SM color schemes. This is going to be wild when We get into the Little Joe I & II series, (The options there are all over the radar screen). On the bright side We should have a series of all the early/late/what-if Apollo hardware by June.
    Carl
  16. Carl (Surfduke) Hewlett
    One More FYI
    The Detail parts & Hinges for the interior of hatch will be one of the very last posts. I am waiting on some stuff from a friend, (Want it to look right). FTR, I will not do a Block I hatch, or CM, (Out of respect for the Apollo I crew, (I hope this does not cause a rift, with the folks wanting a complete set)).
    Carl
    P.S.
    Thanks to the Admin. for the last post of update files!
  17. Ron Caudillo
    Ron Caudillo Creative Advisory Consultant Moderator
    I have Acrobat at work and can separate the individual pages if you want.
    Best Regards,
    Ron Caudillo
  18. Carl (Surfduke) Hewlett
    I will forward todays to You Ron
    If You have the time please post them. I will have todays update out later on.
    Thanks,
    Carl
  19. Carl (Surfduke) Hewlett
    I have sent the latest update to Ron
    Ron Has the latest update. I hope He can find the time to bust it up, and post it. The inner bulk head, Heat Shield, (In-Flight & Post Flight versions), Transfer Tunnel, Head rest, Foot pan, & Much More, are in there. I will get the interior control panels & Storage areas in the morning. The parachutes will also be a challange, (any ideas on how to show them stored?).
    Carl
  20. Ron Caudillo
    Capsule Model PDF pages
    Hi all,
    Here are the first 5 PDF files of the individual pages of Carl's excellent Apollo capsule!
    Best Regards,
    Ron Caudillo
