  1. timrock
    timrock Active Member
    if they dont actualy start a fire they would burn out,start to smoke and the car would stop running.they would also melt together.
    you need those connectors i suggested.
  2. A J G 3 6 6
    A J G 3 6 6 Member
    How would you gear it?
  3. timrock
    that would depend on where i am driving it.the bigger the area the higher you would want to gear it.
  4. A J G 3 6 6
    A J G 3 6 6 Member
    So all I need is A DuraTrax Streak ESC,14 turn motor,and those Connectors? I might be placing the order tonight.
  5. A J G 3 6 6
    A J G 3 6 6 Member
    I GOT THE STUFF....WHEN I RUN IT ALL I WILL LET YOU KNOW HOW IT GOES
  6. daytondaft
    daytondaft Member
    does anybody know what the fastest motor is for the nitro rc10gt. i want a motor that will make it go over 50mph. how much u think it would cost?
    thanks
  7. timrock
    any motor can make it go 50 mph.depends on the gearing.
  8. shimsham
    shimsham New Member
    are there any nitro trucks that come with reverse
  9. mastmec
    mastmec Member
    T-maxx, Savage, Monster GT, maybe Terra Crusher, Hot Bodies Dirt Demon, Duratrax Thunder Quake
  10. shimsham
    shimsham New Member
    what would be a good rtr nitro stadium truck for a newbee like me
  11. mastmec
    mastmec Member
    Do you want to race it or use for bashing around?
  12. shimsham
    shimsham New Member
    bashin in the yard
  13. shimsham
    shimsham New Member
    looking at nitro rush evo any words of wisdom
  14. mastmec
    mastmec Member
    Any of the HPI trucks are good, go for four wheel drive, works a lot better in grass. Just go for a truck that is well known and you can get parts and upgrades easy. Starter box would be a good choice for a beginner, electric start is ok but its something else to diagnose if it doesn't work, plus the one-way is a pain sometimes. Pull start will just piss you off if it's not tuned right.
  15. A J G 3 6 6
    A J G 3 6 6 Member
    Savage comes with reverse? I thought you needed to get a reverse module.
  16. mastmec
    mastmec Member
    Your probably right, I was thinking one of their kits or RTRs already had it.
  17. A J G 3 6 6
    A J G 3 6 6 Member
    Is 84/15 a good gear ratio? Or is there a better combination?
  18. A J G 3 6 6
    A J G 3 6 6 Member
    I got the stuff today. Its smaller than i thought! I have a couple questions,how do i get the plug on the ESC to the bettery off to put the connectors?How do I get the motor out...and how do I connect the motor to my ESC,do i have to solder with the Speed Secrets?
  19. A J G 3 6 6
    A J G 3 6 6 Member
    I got the motor out...how do I get the pinion gear off?
  20. timrock
    the motor wires you can solder right to the motor.you have to cut the plugs off of the batteries and solder the new ones on.also cut the plug off of the Streak and solder the new plugs on.make sure you solder the red plug to the red wire and black plug to the black wire.
