  1. A J G 3 6 6
    A J G 3 6 6 Member
    I NEED HELP!!!! PLEASE!!!!!!!
  2. timrock
    timrock Active Member
    i think it might be your differential in you tranny (e-rustler) AJ366
  3. A J G 3 6 6
    A J G 3 6 6 Member
    what could i do to it to fix it? Have you ever experianced it?
  4. timrock
    i havent experienced this with the Rustler but i have with other cars.i think you have the planetary differential.if the gears in it dont turn for whatever reason it wont work right and will affect the way the truck steers/turns.
    1.pick up your car
    2.spin one rear wheel
    3.if the other rear wheel spins the same way it Is the Differential
    4.if it spins the opposite then is Not the Differential.
  5. A J G 3 6 6
    A J G 3 6 6 Member
    Mines Not Differential.Is that bad or good?
  6. timrock
    did you build the kit or did you buy it RTR?
  7. timrock
    what do you mean by`Mines not differential`?
  8. timrock
    your talking about a Traxxas Rustler right?
  9. A J G 3 6 6
    A J G 3 6 6 Member
  10. A J G 3 6 6
    A J G 3 6 6 Member
  11. A J G 3 6 6
    A J G 3 6 6 Member
    I was responding to that,number 4,mines not differential.
  12. timrock
    dude you should tell me which way the other wheel spins when you turn one of them.
    also `mines` is not an english word.
  13. A J G 3 6 6
    A J G 3 6 6 Member
    OK? When I spin one,the other one spins the other way. Or with the remote are you talking about?
  14. timrock
    ok it isnt your differential then.you have a prblem with you stering linkage or steering servo i would assume.
  15. A J G 3 6 6
    A J G 3 6 6 Member
    Oh cause I think it started when I was playing inside and I ran into my tv with the front and thats when it stared.LOL
  16. timrock
    take a close look at it.you might have,simply,bend a tie rod or somthing.
  17. A J G 3 6 6
    A J G 3 6 6 Member
    How would you gear an electric car? 15/84
  18. timrock
    you mean your Rustler? 15 pinion 84 spur is cool for playing around.
    if racing,it depends on track length.the shorter the track,the lower you gear it.the longer the track the higher you gear it.
  19. A J G 3 6 6
    A J G 3 6 6 Member
    What will these connectors do? Are they the ones where they store energy or something like that?
  20. timrock
    No.they are low resistance connectors.you need them.if you use the ones you have with that motor,they can start a Fire.
