  1. Overdrive789
    Overdrive789 New Member
    Yo,
    What is the best battery to use with a Trinity Chameleon 2 Pro electric motor?? it has to be under 100$$.
    Thanks
  2. timrock
    timrock Active Member
    Overdrive789,what kind of charger do you have?
  3. timrock
    wayendraton, i would remove the pull start and get an electric starter.the pull start you have on it sounds like it is the wrong one.also pull starts rob power from the engine making your car slower.
  4. mooserman75
    mooserman75 New Member
    i have an ultra lx pro with a force .26 what are the first upgrades i should get?
  5. Overdrive789
    I have a peise of junk MRC super brain 809
  6. timrock
  7. Overdrive789
    thanks timrock!
  8. dirtovallMaster
    dirtovallMaster New Member
    nice battery for a Nicad but NiMH batteries are better.
  9. A J G 3 6 6
    A J G 3 6 6 Member
    I have an e-rustler,and I was runing it outside in the melted snow...and I went through this big puddle and a couple seconds later it just stoped,then it just went haywire. I brought it inside,dried things off. tried to run again and its just keeped going haywire.After like 5 seconds i shut it off. I felt the ESC and it was burning hot.What could be wrong with it? I need help,thanks
  10. mxking171
    mxking171 Member
    hey man i have an electric stampede and i did the same thing i dont no how rich u are but with my stamp when i went through the water it went haywire and started to smoke then i dried it of and i had forwards and no reverse but anyways if it doesnt work im going to say buy an esc that will fit it.
  11. dirtovallMaster
    how fast was your HPI Savage going when it hit the tree?5MPH? or 50MPH?
  12. timrock
    your reciever got wet that would be why it went `haywire`
    most ESCs are sealed up much better than most recievers.
    What kind of ESC and Reciver?
  13. mxking171
    mxking171 Member
    my savage was going 2nd gear full throtle stuck wide open and hit a tree are u dising it?
  14. timrock
    No.it is just that your story doesnt say how fast it was going when it hit the tree or how far away from the tree it was when the throttle stuck open.it says `this shows how tuff the Savage is`but it doesnt show anything.thought i should let you know.
  15. timrock
    Dirtovallmaster what do you race electric or nitro?
  16. Jag
    Jag New Member
    I just bought a Kyosho Ultima Pro buggy, and need the gear cover housing for it. At tower hobby, they have gear cover housings for EP ultima sports, EP ultima ST R and the EP sport buggy. But none for the Ultima Pro. Will any of the other ones fit? OR is there some other style that fits. I've looked around as best I can, ebay etc, but not found one yet for the Ultima Pro. I'm a newbie here, so any advice is greatly appreciated. Also need a wing and wing stay for it, if you have any suggestions there as well.
    Jaggy
  17. Overdrive789
    I also went through the melted snow, and i think i might have gotten water in my esc, and my receiver. wat would be the best way to dry these up??
  18. timrock
    the recievers get wet much easier than most ESC.some guys put thier recivers in a balloon in case that happens.but if it got wet, first thing is turn it off as fast as possible.you can open it and put a hair dryer to it to dry it out faster but eventualy it will dry on its own.if you put a hair dryer to it,make sure you dont heat it up.just keep it away from it enough just to let the blown air hit it.
    also,it wont hurt anything if the electronics get wet,it is just when you have voltage to them while they are wet.that can ruin them.
  19. Trashcanoccupant449
    Trashcanoccupant449 Member
    I just soldered the capacitors and diode to a Tower Hobbies speed secret 14t quad motor and hooked it up to my Duratrax streak ESC and it makes an odd humming noise when its in neutral. The ESC doesn't have any performance issues (switching from forward to brake and glitching) but I was just wondering if the humming is anything to be worried about. The motor only hums when it is in neutral, when I apply the throttle or the brake, the motor sounds fine.
  20. timrock
    it could be a simple throttle adjustment on your transmitter.
