  1. mpracing
    mpracing Member
    I am talkin about the electric, a nitro rustler, an 03, can beat a bandit 1/2 throttle. But electric, once you got everything, your set, but gas is more fun, considering your always tuning your engine, tinkering with set-ups, and the downside you have to pay for gas, glowplugs, and tires tires, if you have THE DOE then go for gas, if you have little time and want an easy day on the track, go with electric.
    mpracing
  2. A J G 3 6 6
    A J G 3 6 6 Member
    Which is just a better car? The T3 or the T4
    thanks
  3. rockshock78
    rockshock78 New Member
    Is a Chameleon 2 Pro 19 turn motor good for my electric stampede???
    I have a 20 turn stock Stinger motor in now, will the Chamleon 2 Pro be faster motor???top speed or accel.???And do you know any good sites to find bodies for my stampede, prepainted???
  4. A J G 3 6 6
    A J G 3 6 6 Member
    For a motor for the Rustler what should I get?
    Trinity P2K2,Green Machine 3,DudeMann P2K2 Pro?
    And one other one...What are the best upgrades for the body(pre-cut and painted)motor,tires,battery..? In advance thanks.
  5. Trashcanoccupant449
    Trashcanoccupant449 Member
    I was wondering if anyone knew if the Kyosho Heavy Duty MKII speed control was water resistant or not?
  6. A J G 3 6 6
    A J G 3 6 6 Member
    HELP WITH THE RUSTLER........
  7. timrock
    timrock Active Member
    mpracing says get a 4000mAh battery?(laughing)the only batteries with that many mAh are lead acid.they weight a ton.3300 is the highest mAh battery that are `C` size NMH cells.2400 is the highest for Nicads.
  8. timrock
    get a motor,for you rustler,that has the lowest # of turns that your speed control can handle.those motor you listed are 27turns.you need somthing around 15.
  9. timrock
    if your speed control cant handle anything lower than 20turn,get a new speed control too
  10. rcosmax
    rcosmax Member
    here you are again tim being rude.....hmmmm....a pattern maybe?
  11. timrock
    i just find it funny how the guy is supposed to be here to solve peoples problems and gave false information.i lead people in the right direction with what i wrote.if you think that is rude then thats your problem.
  12. timrock
    also go back to where you made those rude comments about about me.i responded.to it rcosmax
  13. yrret
    yrret New Member
    How can i set up my Nicad charger to charge Nimh batts? just a resistor in line?
    thanks
  14. yrret
    yrret New Member
    timrock, whats the max volts i can run in a stock RC10T3? i have a 7.2 nicad battery pac that came with the car but can i go up to 8.4? i was looking for longer run times better performance and going to go with NI-MH batts, will more volts burn things up?(i can smell the nitro flames now)regardless, nitro is in the future havent decided if i want a touring car or off roader
  15. timrock
    `max volts`?you would need to tell me what type/kind of speed control you are running in it.not sure what the T3 comes with stock.(RTR)
  16. timrock
    essentialy,there is no limit to the amount of voltage you can put to or horse power you can get out of an electric powered car.there are many factors that come into play.the faster you want to go the more factors.tell me how fast you want to go with you electric powered T3 for starters.and ill take it from there.
  17. yrret
    yrret New Member
    Is got a(stock) LPR electronic digital speed control,looking for longer run X's
  18. timrock
    well if you bought the speed control new and freshly opened the box you should have the specs on it.im not sure but i dont think that came with your kit./....?
  19. yrret
    yrret New Member
    its factory installed.the label on the box says LPR elec.dig. speed control. so can i run a 8.4 batt and how long will a NI-MH last (3000 or 3300) should i disconnect the reverse?
  20. bbdentman
    bbdentman New Member
    I am building a back yard track 105 by 42 to practice on. what I want to do is make it as hard it can be to drive, so I can get better at offroad racing. any idea's on jumps turns or whatever I need to do.
