And for my next creation....
Discussion in 'Science Fiction & Fantasy' started by Cybergrinder, Jan 21, 2019.
  1. zathros
    zathros -----SENIOR---- Administrator Moderator
    Awesome!! :)
  2. Cybergrinder
    Cybergrinder Member Extraordinaire
    And now the main saucer complete
    And a shot of the docking bay?
  3. Rhaven Blaack
    Rhaven Blaack ADMINISTRATOR Administrator Moderator
    You are doing a really good job on this project!
    Cybergrinder likes this.
  4. zathros
    The bottom pic shows great symmetry. :)
  5. Cybergrinder
    And the top of the super-structure complete :)
    Now, to finish the super-structure and figure out lighting :hammerhead:
  6. Cybergrinder
    So the last part of the super-structure done
  7. Cybergrinder
    And now the impulse engines.
    I couldn't leave them flat, so with a bit of lateral thinking...
    I recessed the things! Housing in the top right of the picture
    And completed. Top view
    Underside
    And a side shot
    Now to get it all together with the lights....
  8. Sky Seeker
    Sky Seeker Well Established Member
  9. Cybergrinder
    You should see them lilt up :)
    Sky Seeker likes this.
  10. Cybergrinder
    Saucer attached, I think this is one of the better Federation ship's I've done :)
    And now some teasers :)
    IMG_20190517_202526.jpg IMG_20190519_173255.jpg IMG_20190516_184454.jpg IMG_20190519_173210.jpg IMG_20190516_184509.jpg IMG_20190519_173243.jpg IMG_20190519_173217.jpg
    Papa Mashy, Sudsy, zathros and 6 others like this.
  11. Dagger
    Dagger New Member
    That looks wonderful !!!
  12. Revell-Fan
    Revell-Fan Co-Administrator Administrator Moderator
    BLING!!!!:)
  13. Cybergrinder
    Thanks guys, and it's not done yet :)
  14. Sky Seeker
  15. Cybergrinder
    @Sky Seeker , you're correct, only the saucer itself is attached.
    I finished attaching the secondary hull parts, I waited so that I could get the alignment right.
    And the captain's yacht completed
  16. zathros
    Just a big WOW!!! That ship all lit up is wild!! I might consider a pot to bring the lights down, then again, it just might be the camera, night with bright lights is hard to photograph, another method is making a voltage divider. They are an effective way of dropping voltage and having full voltage on the same circuit. This simple circuit shows how the larger resistance resistor drop 3.3volts from the circuit, but if the LED needed 5 volts, you could still get it by going from ground to the 5V input. The 3.3Volts would not be felt by the circuit. Using Resistors of equal value, you get equal voltage drops, so a 12 or 24Vcc system could really be cut up and be used to wired all kinds of stuff, and all kinds of voltage levels. :)
  17. Cybergrinder
    The supply I'm using to test does pump out a bit more than 5V :)
  18. Sky Seeker
    This lines up well. Nice job! :) :King::King::King:Looks up to par with your usual work which is fantastic!:bowdown::bowdown::bowdown::bowdown::Bravo::Bravo::Bravo:
    Sky Seeker
    :Viper:
    zathros likes this.
  19. zathros
    That's great, then you could make different levels of lighting, typically a diode takes 1.5 volts to turn on. You LED's should have a spec sheet. Using a breadboard, you could make different voltage drop and see how long you can get a diode to light up. Also, if you don't expose the Cathode or Anode, you can cut, and Polish the ends to shape LED's. :)
  20. Cybergrinder
    And, she is complete! IMG_20190521_210840.jpg IMG_20190521_210944.jpg IMG_20190521_210910.jpg IMG_20190521_185650.jpg IMG_20190521_210856.jpg
    "Beauty" and lighting shots to follow once I can create a bit of a "set" :)
    BTW; The stand was tweaked a bit as well....
