And for my next creation....
Discussion in 'Science Fiction & Fantasy' started by Cybergrinder, Jan 21, 2019.
  1. thegreek270
    thegreek270 New Member
    Very nice Work Cybergrinder, keep it up ;)
    Cybergrinder likes this.
  2. zathros
    zathros -----SENIOR---- Administrator Moderator
    That section really came out great!! If I didn't know where the seams were, I wouldn't see them. ;)
  3. Cybergrinder
    Cybergrinder Member Extraordinaire
    That is high praise indeed Zathros, thank you!
    zathros likes this.
  4. zathros
    Word man. :)
  5. Sky Seeker
    Sky Seeker Well Established Member
    Looks great! :Drinks: Looking forward to the greebles!:)
    Sky Seeker
    :Viper:
  6. Cybergrinder
    What I have been doing is working on the top section of the secondary hull so I can figure out the alignment & cuts required for the supports & wiring. Pic coming soon! Then I'll greeble the bottom section (not much on the top)
    After that I'll join the nacelles....
    Going to need more clear LED's for the saucer.... :)
    Sky Seeker and lyter1958 like this.
  7. Cybergrinder
    Here we go, top of the secondary hull!
    80's lego guy approves!
  8. Cybergrinder
    Shuttle bay attached
    And now, the moment of truth, attaching the wings and nacelles. Nacelles not attached yet
  9. Cybergrinder
    And here they are....
    attached!
    Wiring and gaps to be completed :)
  10. zathros
    In terms of quality of construction, I think this is your best model yet!! It looks excellent!!! :)
    Gandolf50 and Cybergrinder like this.
  11. Cybergrinder
    High praise indeed! Thank you Zathros!
    zathros likes this.
  12. Sky Seeker
    You nailed those nacelles! Great job!:Drinks::Drinks::Drinks:
    Looking forward to seeing them lit up.:)
    Sky Seeker
    :Viper:
  13. Cybergrinder
    @Sky Seeker , there is a post earlier in the thread with them lit up :)
    I need to do the wiring before anymore lighting photos as the supply is entering via the nacelles, each nacelle carries the seperate polarities.
    zathros and Sky Seeker like this.
  14. Cybergrinder
    Now, who's for some tea? :)
    Yes, I've started on the saucer section.
    Underside
    And the supports
  15. Revell-Fan
    Revell-Fan Co-Administrator Administrator Moderator
    What a nice dish! :)
  16. zathros
    Those formers aren't glued down in that pic, are they? Also, in real aircraft, to make formers stick to compound surfaces, the binding agent is a very thick, think, "thick peanut butter, no nuts" as gooped on around an inch thick and wide. This holds the composite surface to the formers, and takes up any difference in shape. Think compound curve saucer, straight edged top of former. Put some longitudinal formers to make the framework even on both sides. You will have a very strong saucer section. Looking really good. ;)
  17. Cybergrinder
    Formers not glued down :)
    that was just a test "fit"
    Another test fit with the formers for the underside. I can see a challenge getting the lighting right for some of the windows....
    I'll figure it out though!
  18. Cybergrinder
    Good news, I figured out how to do the lighting :)
    Lots of chopping to the saucer base required for the LEDs and some delicate surgery to the B former...
    Sky Seeker and zathros like this.
  19. zathros
    You are really putting your Cyber nose to the Grind stone!! ;)
  20. Cybergrinder
