AH, Nr 2/2003, P-39N Airacobra
Discussion in 'Aircraft & Aviation' started by edikk, Mar 10, 2006.
  1. edikk
    edikk Member
    I present you assembly of model Halinski P-39N Airacobra.
    [​IMG]
  2. edikk
    edikk Member
    It is a little about the process of assembly.
    Assembly of air-frame.
    [​IMG]
    [​IMG]
    [​IMG]
  3. edikk
    edikk Member
    Has decided to add from itself a machine-gun section.
    [​IMG]
    [​IMG]
    [​IMG]
  4. edikk
    edikk Member
    Body in the assembly
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  5. edikk
    edikk Member
    Construction of structure of a wing.
    [​IMG]
    [​IMG]
  6. edikk
    edikk Member
    And it already a wing in the assembly.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  7. edikk
    edikk Member
    Assembly moves ahead. The basic racks of the chassis.
    [​IMG]
    Wheels turn. Has added brake hoses.
    [​IMG]
    [​IMG]
  8. edikk
    edikk Member
    The following step is a forward rack of the chassis.
    [​IMG]
    And final step - it blade.
    [​IMG]
  9. edikk
    edikk Member
    Well having collected other trifles on an output it is received ready model.
    That that has turned out at me already in the collected kind - to judge already to you.
    General view.
    [​IMG]
    [​IMG]
    [​IMG]
  10. edikk
    edikk Member
    And the general view with all that can open.
    [​IMG]
    [​IMG]
    [​IMG]
  11. edikk
    edikk Member
    The rear view:)
    [​IMG]
    [​IMG]
  12. modano1
    modano1 Member
    Beautifully done, this is my next project, hopefully next week sometime. Good job!
  13. edikk
    edikk Member
    And now a little a detailed kind:
    [​IMG]
    [​IMG]
    [​IMG]
    Kind from under a bottom:)
    [​IMG]
  14. edikk
    edikk Member
    The chassis my weakness:) Once again I shall show.
    [​IMG]
  15. edikk
    edikk Member
    Well, we shall glance in a cabin.
    [​IMG]
    [​IMG]
    In general Halinski to collect pleasantly. Though I with the alterations and "completions" was mistaken, but the result in general has liked.
  16. edikk
    edikk Member
    The end :).
  17. modano1
    modano1 Member
    Is the canopy vaccum-formed or is it transperency sheets cut to fit?
  18. edikk
    edikk Member
    vaccum-formed. I bought ready. But the back part appeared less, therefore I did it.
  19. rockpaperscissor
    rockpaperscissor Member
    Materful work edikk! I have this model but haven't worked up the courage to start it yet. Since I'm more of a vehicle guy (at least for the present) I also checked out the link to your Mercedes build. Again, a fantastic build. You are very talented.
    Regards,
    Don W.
  20. cmdrted
    cmdrted Active Member
    Beautiful! Great detail work,The cockpit is excellant, Thanks for share ing with us, T
