After the last build debacle heres my Sand Crawler progress
Discussion in 'Science Fiction & Fantasy' started by Jadriancz, May 7, 2016.
  1. Jadriancz
    Jadriancz New Member
    Printed out the pages on A4 cardstock
    Built the lower body
    connected 2 of the 3 upper body parts
    zathros, lyter1958, bgt01 and 3 others like this.
  2. Jadriancz
    Started the assembly of the tracks
  3. Rhaven Blaack
    Rhaven Blaack ADMINISTRATOR Administrator Moderator
    You are off to a good start!
    It does look like you can greeble it out.
  4. bigpetr
    bigpetr Designer/Master Modeler
    Great, nice start. Holding my thumbs :).
    Where this model can be found to download?
  5. nero-on-fire
    nero-on-fire New Member
    bigpetr likes this.
  6. Jadriancz
  7. Jadriancz
    Tonights progress, I got the tracks completed...
    Had to set aside and work on my Lindberg Russian T-80 while letting the glue dry.. Yep the T-80 is Styrene and not paper.. The joys and benefits of multiple hobbies.. :)
  8. Jadriancz
    Need more xp under my belt to do that.. This is only the 5th paper model I have attempted to build but will get there soon.
    lyter1958 and Rhaven Blaack like this.
  9. Rhaven Blaack
    You are doing good. Just take your time and enjoy the build.
  10. zathros
    zathros -----SENIOR---- Administrator Moderator
    Back on the Horse! Good for you! :)
    Jadriancz likes this.
  11. lyter1958
    lyter1958 Esteemed Member
    everything is looking really good so far thumbsup
  12. Jadriancz
    Finally completed... Need to do a few touchups on some of the seams but done..
    lyter1958 and zathros like this.
  13. zathros
    It's coming out very well. This model can be "bumped out very easily. By taking a close work on how the track assemblies are made. Look at the track detail Pic, all you need to do is double up on the thickness of the tracks. Cut out the Black areas of the track, glue the triangles of the track onto the track. on the inside, double up on the drive wheels, for strength, and for the tracks, just cut on the edges so the look wide enough for the wheels to grab. Cut out rings, and lay them (with glue) over the rings, and cut open the oblong vertical openings. This will bring much life to your model. If you printer on regular printing paper, you can cut out body panels, and glue them onto the body, then instead of a box, it will "POP" to life. This is very easy to do, just takes a little time. Any questions, send me a P.M., to make sure I get it, I'd be more than happy to help you, if you wish. If the model had not come out so nice, I would not have made the suggestions! :)
  14. zathros
  15. Jadriancz
    I will keep this in mind for the next time I build this (remember this is only the 5th paper model I have attempted building but only the 3rd completed after the Tie & AT-ST issues)... Will also probably use photo paper instead of regular paper to enhance the details.. Love the coloring on yours thumbsup Do you have any build pics of how the track mounts were done?
    The design I used (attached) seems to be a much simpler version of the one pictured above as well.
  16. zathros
    You create the way the tracks, "whatever works"! I would advise against Photo quality paper, for many reasons. If you were to print on normal paper, you could glue those on each panel outlined on the crawler. It doesn't matter how few models you have made, this will bring your model to a new level, and once you start adding, it becomes addictive, because the results look so fine , you'll do the whole model, and it will be exceptional. I have the model, and will work on the new pieces tomorrow. You will see, this is an easy "Greebling" project. :) :)
  17. Jadriancz
    Another thing I noticed is that the paper (staples brand) I use mutes the colors alot..
  18. zathros
    Get the "Bright" paper they sell, didn't forget about the crawler legs. I was able to extract the pages from the .pdf, but don't know if they are in the same scale. Could you measure the over all length of one of your track assembly outside plates, the over all length, to let me know? I need the measurement show like in the pic below:
  19. Jadriancz
    On my model those are 4cm
  20. zathros
    4 cms? Are you sure, that's awfully tiny!?! I extracted the page, you are right, boy that's small. In any event, you could glue these over your existing one. All the doubled parts are to be cut out, and added on top of the parts of the Crawler, to make it "POP". The drive sprockets are NOT supposed to be showing, this is an error on this model, from the drawings I have seen, they look more like this:
    My parts for you, to be printed on letter size paper (U.S.) if you can't get this size paper, let me know, and I will redo it in the size you use, use the extra parts and really make the model pop. :)
    Sky Seeker, bigpetr and Jadriancz like this.
