A4 Paper sources
Discussion in 'North America' started by Prowler901, Nov 14, 2006.
  1. Prowler901
    Prowler901 Member
    I've searched the forums but couldn't find any info on this. Where are you guys getting A4 paper of appropriate weights for modeling?
    Regards,
    Todd
  2. rickstef
    rickstef Guest
  3. Prowler901
    Prowler901 Member
    Super. Thanks. :) I must have missed it while scanning through the search results. Thanks for pointing the way :)
    Regards,
    Todd
  4. Amazyah
    Amazyah Senior Member
    Rick,
    Have you recieved your order yet?
    I just took a look at the three links you have in your other post and it appears to me that you just bought real expensive copy paper.
    I have a package of copy paper here that says it is 20lb or 90kg.
    The paper you bought says 110-135kg which should be roughly 24-25lb paper.
    A good paper but nothing near even a light card stock.
    Russell
  5. rickstef
    rickstef Guest
    i got the paper and i have used it
    with outstanding results
    Rick
  6. rickstef
    rickstef Guest
    thing is, the paper i bought feels alot thicker than any 28 lbs paper i know of
    and it just a bit thinner than the 65 lb cover stock i use from Wausau
    Rick
  7. Amazyah
    That's cool! As long as you are happy, that's all that counts.
    I was just afraid that you were going to be sorely disappointed.
    Ruusell
