A pair of Bf-109Gs
Discussion in 'Aircraft & Aviation' started by cmdrted, Jan 2, 2007.
  1. cmdrted
    cmdrted Active Member
    I wasn't a Dallas fan until Romo got the call. He reminded me of Joe Montana in the first few outings. I guess the other teams needed a few games worth of films on him to figure him out. I think they have his number! As for dedication, I have a bit of insomnia, (or insanity my wife says), the only problem is I'm not too functional after @ 1230 -1 am, just awake! Can't do many detailed model things at those hours, funny as I work shift work at an inner city hospital and can still function in that capacity. As for close ups, I've been playing with the camera an "old" canon power shot A80. Still has buttons I don't know a thing about! I just shoot 'em man I don't know what makes 'em go! Well some work to be done before the Eagles game, (my wife's home favourite).
  2. cmdrted
    In between plays and Pats game I managed to finish the Orlik's "tail feathers"... Here's a close up of the fixed parts, A bit more complex than the Maly, maybe unneccessarily so but still good fit.
  3. cmdrted
    And another from diferant angle.
  4. cmdrted
    The biggest differance is in the actual interface between the rudder/stabs and the fuselage. The Orlik is more favourable to positioning the surfaces in a stabs down rudder kicked angle. The Malys surfaces are dead flat and allow very little "candid" positioning.
  5. cmdrted
    Another shot showing the finished tails...
  6. cmdrted
    A quick shot of the rudder and stab differances, Maly L Orlik R. The Orlik mateing surfaces are rounded, Maly's flat. It wasn't any more difficult building up either set with each companies' differant designs so if I had my druthers I'd pick the Orlik for this section. Not "much" more to go, 4 wings, 2 sets of props, landing gears, canopies and small details.
  7. cbg
    cbg Member
    Ted,
    Am really enjoying this side-by-side build. Found a pic of a G-4 with tropical filter for you.
    [​IMG]
    Noticed that the Maly horiz. stab has fillets whereas the Orlik does not? Or are you still finishing that section?
    cbg
    p.s. Am rootin' for the Colts this year.
  8. cmdrted
    Thanks for the pic, no fillets for the Orlik, it would've been better with fillets, there is a tiny gap that would've been completely gone with them.
  9. cmdrted
    Well the Eagles did it, another nailbiter. After a much relieved win, I started on the Maly left wing. Nothing overly special, prefold the wing shape and insert the wheel wells...
  10. cmdrted
    Place in the wing bones and instead of using the kit's trailing edge flaps to glue the edges I cut them off and used some scrap strip placed 22mm from the trailing edge...
  11. cmdrted
    That's 2mm! Then wrap around the skin and join at the trailing edge. One secret to lining the edge up is when you are forming the wing gently start the forward/leading edge, then fold the wing over and line them up perfectly with the trialing edge. The run your finger long the leading edge, gently squeezing that edge. This preforms the entire skin, so all you have to do is wrap it around the spars and join the rear edge. It also helps eliminate the warping that "stretching" to reach the edges causes.
  12. cmdrted
    The tips wwere next, preform them with a burnishing device of some sort, I use a crochet needle and gummi eraser...
  13. cmdrted
    I usually glue the top tip first...
  14. cmdrted
    Then add the bottom...
  15. cmdrted
    Just about finished left Maly wing, I dry fit the airscoop, it will be placed after the wings are fixed to the fuselage...
  16. cmdrted
    top view,, sorta anticlimatic...
  17. cmdrted
    The center mounting piece. This is a wedge shaped thing that presets the wing dihedral. You wrap the bottom skind around it...
  18. cmdrted
    Then glue it to the slotted area on the fuselage...
  19. cmdrted
    The wings will glue up flush with the edges when both are finished. I'll do the right wing and move on to the Orlik later...
  20. cgutzmer
    cgutzmer Guest
    awesome! do you eat or sleep?
    Chris
