A new chassis for a Bachmann U33B.
Discussion in 'The Academy' started by Ray Marinaccio, Jun 16, 2004.
Thread Status:
  1. Ray Marinaccio
    Ray Marinaccio Active Member
    The motor is marked "Kader 881" , so I assumed it was a Bachmann.
  2. Ray Marinaccio
    These are the dimentions for the fuel tank.
  3. Ray Marinaccio
    The two ends and tank wrapper were cut from .010" brass sheet.
  4. Ray Marinaccio
    The bends were formed starting from the inner bends and working outward.
    The sheet was clamped between two 1/4" steel bars.
  5. Ray Marinaccio
    The first two bends completed.
  6. Ray Marinaccio
    The third bend in position ready to be folded.
  7. Ray Marinaccio
    Twisting the bars to make the bend.
  8. Ray Marinaccio
    A 3/16" bar was used to make the final bends.
  9. Ray Marinaccio
    The completed wrapper.
  10. Ray Marinaccio
    The ends and wrapper were test fitted.
    Some filing was required to get a good fit.
  11. Ray Marinaccio
    The parts were removed from the frame and the ends were soldered on at the bottom corners only.
  12. Ray Marinaccio
    The tank was refitted on the frame and the ends were soldered.
  13. Ray Marinaccio
    Then the sides were soldered to the frame and then all the seams were soldered.
  14. Ray Marinaccio
    This is the frame after all the seams were filed.
    The next installment will be the air tanks.
  15. Ray Marinaccio
    The air tanks were made from two 1" lengths of 7/32" brass rod (a float arm from a toilet).
    The ends were shaped with a file as they turned in the lathe.
    .020" holes were drilled in the ends for the air lines to be inserted into.
    The tanks were then soldered to the mounts.
  16. Ray Marinaccio
    The fuel tank was filled with ballast (I used some shot from an old shotgun shell)then the filler hole was sealed with caulking.
  17. Ray Marinaccio
    The trucks and motor were installed and wired.
  18. Ray Marinaccio
    Driveshafts were then fabricated.
    I didn't have the Bachmann coupling so I fabricated the ball end and shaft then pressed it into an Athearn #90106 coupling that I drilled out and removed the spline from.
    I would recommend using ready made universals from NWSL.
  19. Ray Marinaccio
    Once the shafts were installed it was ready for a test run.
    Drilling the holes in the coupler mounts will be done after I finish the pilots to determine the correct location.
    The air lines and Detail West fuel fillers will be added latter also.
  20. Ray Marinaccio
    At first it seamed a little noisy in the trucks.
    Some cardstock shims on top of the square worm bearings quieted them down and its running great.
Thread Status:
