A Cold Storage Distribution Centre
GS4
World's Greatest Hobby
Jul 7, 2008
11
:wave:
Hi there fellow modellers,
I guess it's time that I show some of my modelling efforts. So I decideed to start with my Cold Storage Distribution Centre. It could also be used as an ordinary warehouse, just change the sign.
A front view
A few close up shots
The lefthand end of the building - don't think these two old geezers know that the boss is at the other end of the building
One of the freight doors
Cleaning up the property
The righthand end of tthe building - that's the boss talking to the foreman
A look along the tracks
and a view frm the opposite end
A Cryogenic reefer full of frozen produce, is being spotted at the number 2 freight door
That's it for now, will post construction photos later
Cheers, Simon :thumb:
GS4
Jul 7, 2008
11
Thanks for the comments guys, they are much appreciated
Cheers, Simon
cnw1961
846
Germany
Simon, you did a very nice job. Especially all the little details and scenes around your cold storage make it come alive. Show us more of your modeling :thumb:.
4,501
Lakewood, Ca.
Very nice scene. The only question I have concerns the choice of building for cold storage. Out here metal buildings are used for relatively small industries like heavy equipment dealers, and such. A lot of the older wholesale produce warehouses are metal and will have walk in boxes back inside the dock for produce which needs to be kept under refrigeration. All of the cold storage warehouses that I've seen around So Cal are concrete tilt up construction. Are they different in your part of the country?
GS4
Jul 7, 2008
11
Thanks for the comments guys!!
Russ, I've no first hand knowledge of what tye of construction is used in the various parts of the USA, for the building of cold storage facilities, as I live in the City of Cape Town in South Africa.
The story behind my choosing to use a metal structure for the construction of a cold storage facility is as follows:-
W. Vester was looking for a place to build a cold storage facility in the City of Bolder Creek, in Oregon. Now like most investors, he was a frugal man, who checked both sides of a coin before spending it. He came across an unused warehouse, the building in question, and upon closer inspection, decided that it would be financially beneficial to convert the existing building, rather than to build from new. So the interior of the warehouse was rebuilt with with cold rooms made from the latest materials, with the refrigeration plants installed outside under cover for ease of maintenance or replacement. Which also explains why there are ventilators on the roof. They are left over from the original use of the warehouse and as mentioned before, W. Venter, being the frugal man that he is, did not see the sense in spending money to have them removed, so there they'll stay until who knows when.
Cheers, Simon
4,501
Lakewood, Ca.
Good one, Simon. I suspect a small cold storage plant would not be concrete tilt up since as far as I know that is an expensive method of construction. I see so many cold storage plants, dairies, and ice cream plants out here that are concrete tilt up that I sometimes forget that a small company might use a different form of construction. The concrete is preferred because it is a better insulator than metal, but I've worked at produce wholesalers who used a metal building with refrigerated spaces inside as well.
Dec 6, 2007
128
rbdhd.t35.com
Simon,
I really like what you have done here. I would like to know more about how you created the brick foundation of the building. Did you make it or use some styrene sheet?
Dave
GS4
Jul 7, 2008
11
announce1
Hey there fellow modellers!!
Thank you all for the compliments, they are much appreciated.
Dave, the foundation brickwork is made from "Faller" 'N' scale printed card.
What follows is a photographic presentation of the project. Basically the structure consists of a balsawod core with Plastruc corrigated styrene sheeting glued onto the balsawood. The white edgings are Evergreen styrene angle strips. I almost forgot, the model is built in HO scale (3.5mm/ft --- 1/87th scale)
The raw materials
Attaching the one end wall
The other end wall
The front wall
Both doorways are cut out
What a difference a coat of paint makes
The next step is the making of the cargo doorways
The materials required
Each weather diaphram consists of 30 parts
Door assembly
The completed doorway
Some of the accessories
A refrigeration unit ( a Walthers roof top A/C)
The security fence (from a Kibri fence kit)
and finally the sign
Now for some more progress shots
With the backdrop in place
Preparing the base for scenicing
The finished project
Cheers, Simon :wave:
