1/72 tu-160
Discussion in 'Aircraft & Aviation' started by yukiyuji, Apr 17, 2006.
  1. yukiyuji
    yukiyuji Member
    haven't built papermodel aircraft a long long time...........
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. yukiyuji
    yukiyuji Member
  3. Jim Krauzlis
    Jim Krauzlis Active Member
    Good to see you again, Yuki!:)
    Is this a scratch build, one you designed yourself?
    If a kit, can you tell us which one?
    Looking forward to seeing more.
    Cheers!
    Jim
  4. yukiyuji
    yukiyuji Member
  5. yukiyuji
    yukiyuji Member
  6. yukiyuji
    yukiyuji Member
  7. yukiyuji
    yukiyuji Member
  8. yukiyuji
    yukiyuji Member
  9. yukiyuji
    yukiyuji Member
  10. yukiyuji
    yukiyuji Member
    Jim:
    this is hobby model 1/33 tu-160 model
    but I change the scale to 1/72 to match other model aircraft i built,
    and the other side this model is very simple for 1/33 ,
    so i change to 1/72 and rebuilt more part
  11. Ashrunner
    Ashrunner Member
    Nice work scaling down the Blackjack. Were the engines scratch built? I don't remember seeing the blades in my kit, but its under a ton of junk (spring house cleaning and rearranging things) and temporarily lost.
    In any case, it should be a nice model when completed. I can't wait to see it.
    Ashrunner
  12. yukiyuji
    yukiyuji Member
  13. NYC Irish
    NYC Irish Member
    Nice work, but what is the spray paint lines all about?
    John John
  14. hpept
    hpept Member
    NYC Irish, it seems to me a plastic modeller technique. It's used to stress the panel lines. In plastic models, panel lines are usually engraved. If, prior to paint the entire model with the final color, you follow each panel line with another colour (metal in this case, but it could also black, for example), the following overall painting will be much less "flat" and more real life-like, expecially if you paint with airbrush and don't completely cover the underneath colour.
  15. Texman
    Texman Guest
    Correct, in the "other world", they are calling it pre-shading the panel lines. In the olden days, you would use a thinned paint wash to accent the lines. As techniques progressed, chalks came into play. Now, pre shading the all the rage.
    Ray (previous other worlder)
    Maybe call them plasties?
  16. yukiyuji
    yukiyuji Member
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    另外,也開始做這些東西......
  17. yukiyuji
    yukiyuji Member
    工作忙碌沒什麼進度....
    [​IMG]
    花了很長一段時間,總算把機頭打磨好了...
    [​IMG]
    發現機尾很重,很不專業地塞一堆鉛....
    [​IMG]
    機頭總算上去了,這個難搞,因為零件都不合......
    [​IMG]
    由另一個角度看....
    [​IMG]
    之前用噴筆噴實在很累,考慮成本過後似乎噴罐比較化算,於是買了一罐雙星噴罐
    [​IMG]
    每次進模型店都逃不過出血的命運...又多了一盒收藏品,買的速度永遠比做的速度快....
  18. fluthecrank
    fluthecrank Member
    tip for your experience..............
    Hi yukiyuji,
    I feel a very big passion in your work and your pics !! So I want to give you a tip:
    glue the formers on cardboard of about 0.5 or 1mm thickness before assembling.
    That makes your framework more solid.
    For example I show you an image of my F-117, the framework was very complex and impossible without reinforcing by cardboard, have a look:
    [​IMG]
    best regards FLU
  19. yukiyuji
    yukiyuji Member
  20. yukiyuji
    yukiyuji Member
