1/144 Aviatik Berg d-1 build
Discussion in 'Aircraft & Aviation' started by Texman, Aug 17, 2005.
  1. lunarhighway
    lunarhighway Member
    looks really nice! can't wait to see it with the wings on!
  2. lunarhighway
    lunarhighway Member
  3. Texman
    Texman Guest
    Here is the fuselage with the seat, fuel tank, engine, radiator, lower
    wing spar and 6 rolled exhaust tubes. Sure wish I had a better camera
    for the pictures.
  4. Texman
    Texman Guest
    for the pictures.
  5. Texman
    Texman Guest
    These two pictures show the lower wing installed and the upper wing
    with the stiffener and rigging wires installed.
  6. Texman
    Texman Guest
  7. bfam4t6
    bfam4t6 Member
    It's starting to look like a plane. :) Great work Ray.
  8. bfam4t6
    bfam4t6 Member
  9. Willja67
    Willja67 Member
    Looks really nice. Some info on how to work with such small pieces would be helpful(for those of us with big clumsy hands).
  10. Willja67
    Willja67 Member
  11. Texman
    Texman Guest
    Willja67,
    There is really nothing special I do to work in this scale. Almost all of the techniques I use are the same as what you would use in the larger scales, only adapted for smaller use. Such as, only using
    one side of a doubled/folded over part, or using
    regular printer paper for rolled parts. And, it does
    need to be a little gentler cutting out parts. This small, and one slip of the blade cuts your plane in half!
    Ray
  12. Texman
    Texman Guest
    Willja67,
    Ray
  13. Getter1
    Getter1 Active Member
    Texman, what did you use for the rigging?
  14. Getter1
  15. Texman
    Texman Guest
    Getter,
    I am using a .004 clear nylon thread. Scales well,
    doesn't sag alot, and can be tightened up with
    a soldering iron if need be.
    Ray
  16. Texman
    Texman Guest
    Getter,
    Ray
  17. Texman
    Texman Guest
    And the saga continues..
    Here are the wing braces and the tail surfaces. The yellow square
    is the 1 inch square on my cutting mat.
    The next series shows the tail surfaces and wing braces installed.
  18. Texman
    Texman Guest
  19. Texman
    Texman Guest
    Now with the top wing installed, however the rigging is not
    threaded through yet.
    Ray
  20. Texman
    Texman Guest
    Ray
