1/144 Aviatik Berg d-1 build
Discussion in 'Aircraft & Aviation' started by Texman, Aug 17, 2005.
  1. Texman
    Texman Guest
    Howdy ya'll,
    I am going to attempt to show the build of a 1/144 scale Aviatik Berg d1.
    The first step is to take the 1/50 kit by Marek, distributed by DeWayne Barnett, and scale it down. With a wingspan of 25 feet 3 in, this comes out to 2.25 inches (5.7 cm).
    Here a two quick pics to give some idea of the size we're working with here. If you look closely, I have already drilled the holes in the
    wings for the rigging.
    More later
    Ray
  2. Texman
    Texman Guest
    Howdy ya'll,
    More later
    Ray
  3. lunarhighway
    lunarhighway Member
    finally another small one! :D
    good luck with all them tiny bits...looking forward to see the progress!
  4. lunarhighway
    lunarhighway Member
  5. Getter1
    Getter1 Active Member
    That's awesome, another mini builder and in WW1 too :D Currently I'm building a Fiddler's Green Siemens Schuckert DIII in that scale. I'm building it side by side with a larger 1/33 version as well.
    I think your's is gonna be tougher to assemble have much more parts than the simpler F.G. designs. Good luck, can't wait to see more.
  6. Getter1
  7. Texman
    Texman Guest
    Got most of the fuselage done. About 3 hours of off and on work. 12 parts installed so far. Still need seat, engine, windscreen and radiator.
  8. Texman
    Texman Guest
  9. Jim Krauzlis
    Jim Krauzlis Active Member
    Way cool, Ray! :D
    What weight paper do you like to use at this small scale? And another question, if I might...what type of paper are you using for the formers, which Marek recommends be 0.5 - 0.8 mm in the 1/50 scale?
    She's coming along really well, really looking forward to more pics!
    Cheers!
    Jim
  10. Jim Krauzlis
    Way cool, Ray! :D
    Cheers!
    Jim
  11. bfam4t6
    bfam4t6 Member
    Awesome! The fuselage looks great so far. I can't wait to see it with all of the finishing details added.
  12. bfam4t6
    bfam4t6 Member
  13. Gil
    Gil Active Member
    Hey Rey!
    Don't sneeze or you'll have to start over...,
    -Gil
  14. Gil
    Gil Active Member
    Hey Rey!
    -Gil
  15. Texman
    Texman Guest
    Jim,
    I use 67# cardstock for most of the heavy structures, and then use a
    second copy on regular paper for the smaller and rolled type details.
    For the formers, depending on where it is, I use either a single
    or double layer of the same cardstock.
    Ray
  16. Texman
    Texman Guest
    Jim,
    Ray
  17. Nick L.
    Nick L. New Member
    That looks really cool! Good job so far, can't wait to see the finished product! 8)
  18. Nick L.
    Nick L. New Member
  19. Jim Krauzlis
    Thanks, Ray! :D
    That's pretty much what I do too! I've tried rolling the 67# stuff, but it just doesn't finish off as well as the regular paper does...and I like to start the roll with a bit of a tag, if you will, to get the thing going, followed by the printed portion. I did do the engine cylinders on the Pzl-11 using 67#, but was never very happy with the thick edge (at least it seemed thick to me when I was working on it) it ended up with.
    Looking forward to seeing more updates...I love the way this build is coming out, especially in such a small scale!
    Great stuff!
    Cheers!
    Jim
  20. Jim Krauzlis
    Thanks, Ray! :D
    Great stuff!
    Cheers!
    Jim
