Dented Rick
Human
Now is my turn to ask: where have you got those M37 Cadian Adamantium blade, and Bolter rounds?
the Bolter rounds came with the Bolter gun i did earlier (I just hadnt done the rounds yet) and the Blade came with the Lasgun
that's my planDepends. GW tournament play: probably not (unless you make it out of a GW figure/vehicle box and leave the bottom unpainted to prove it was made out of GW material). Although I would argue if you do a good enough job building and painting, they'll never know the difference unless you say something.
As always, your work is TOP NOTCH!
It always AMAZES me how you are able to build these models with such detail at such a small scale. Everything is CLEAN, CRISP, and SHARP!
KEEP UP THE GREAT WORK!!!
YES, You have been THOROUGHLY MISSED!!!
I have missed seeing all of you COOL micromachine WarHammer 40K build threads.
I am glad to see that you are doing the Marauder.
You are off to a GREAT START on this one. I will be following this build!!!
I made this for a friend a few years back. It was a fun build. If ever I get around to rebuilding it, I intend to greeble it out!!!
Life is a bit hectic right now, Soren is out of school for the summer, and ive been spending time with him, plus Anna just got back from the field and is getting ready for a deployment soon, and spending time with her before she goes trumps everything else. But I get a little time every now and then (mostly in the morning) that I can work on the Marauder. so although this build will not go as fast as my others, it will get done
