Warhammer 40K
Wow, you been crankin' dem out! I miss watching you build them! :)
Rogerio Silva
Rick
How long is it? 3in (7.5cm)? Because it looks already incredible, and knowing that you like small scales, makes it even greater! :cool: :cool:
Rick
Thanks, yes it's about 3 inches (7.5cm) From the pdf, I just set my printer to print 4 pages per sheet....so i figure these are around 45 - 50% of the original size.
I have to say that watching your builds is quite interesting and enjoyable.
Your models always turn out better looking then the GW plastic versions.
THIS ONE IS NO EXCEPTION!!!
KEEP UP THE GREAT WORK!!!
Thanks Rhaven, I take my time, and try my best. Dark Angels Sicaran Complete.....the side turrets are not only Rotatable, but also the guns can rotate out 15 degrees :) (Im getting better) ;)
2013-11-01_17-33-44_926.jpg2013-11-01_17-33-54_482.jpg2013-11-01_17-34-12_824.jpg2013-11-01_17-34-27_685.jpg2013-11-01_17-34-39_915.jpg
OUTSTANDING JOB!!!
I like how you were able to make the side turrets move.
Like I said, it does not even look like paper. It does (however) look better then the GW models.
KUDOS TO YOU ON A FINE JOB WELL DONE!!!
OUTSTANDING JOB!!!
Thanks mate....I love how this one turned out, and glad I took the extra time on it :) so far one of my Favorites out of the micro WH40K builds
Your collection is MOST IMPRESSIVE!!!
It looks like you have a pretty good OFFENSIVE & DEFENSIVE FORCE there!!!
You should be very proud of yourself!!!
Watching your build threads is always a pleasure.
Thanks M8.......the Balance is entirely on accident....Ive been merely going from one to the next, Building the ones I thought were cool looking, while being able to micronize without losing too many details :)
johanvanacker
I think that building this small just shows your skills in papercraft. I'm currently going the other way, by enlarging models from A4 to A3 size.
Putting the retaining walls on, and i noticed the measurements were a bit off (top pic)..... No problem, just cut the front section off (bottom Pic) and re-attached inside (Finished pics in next post) Honestly, I like how it looks.
here's the finished build. Sorry about the lack of pics, but like I said, my Camera is real wonky right now. hit or miss.
Anyway, you can see how i corrected the retaining wall, and added the little greebles. the cannon was easy, with only a minor modification where the legs mount to the floor, but otherwise, Im happy with the result :)
2013-11-21_11-57-02_737.jpg2013-11-21_11-57-15_564.jpg2013-11-21_11-57-24_851.jpg2013-11-21_11-57-39_627.jpg2013-11-21_11-57-51_703.jpg
