AAANNNDD Back to the snowspeeder..
i printed the orginal hull sheets again and put the real prop picture at the screen.
Looked where the plating is put and drawn it on the orginal.
then glued it on a thin carton and cut it out.
after the cutting part i took of the orginal papercraft hull sheet and glued the pieces on to the new grey skin.
i made 3 different grey-tones .
And now the half part of the snowspeeder side 1 is glued on...
and took off again (because i forgot a piece of hull) and put back on again
and after that i saw that i forgot the screw holes F****K
and i couldn't take the hull parts of again because the glue is dry..
So......i try to drill them with a dremel....when i find one.
14932
