Let's call him: "Fang" !!
I carefully cut out the teeth, taking note and reference to the contours of the attaching surface inside the mouth. I trimmed each cut edge so that the tooth stood at the correct angle. I glued all the teeth into position with ca glue. I realize the teeth are not the same as the original model, but call it artistic license
, and besides, I think it gives the head are more menacing and vicious look.
While the teeth were drying, I carefully went around the assembly and touched up any areas that needed colour, like mis-coloured join lines and folds where the print had cracked.
Once I was happy with the touch ups and general appearance, I coated the whole assembly with 3 coats of acrylic matt varnish from an aerosol can. The first coat was only a light dust coat, without getting it too wet. The mist coat seals the print and creates a good bond for the next two coats. It is important to let each coat dry well before adding the next coat.
I left this over night to harden, ready for the final touch.
I used gloss acrylic floor wax (Future) to give the inside of the mouth and tongue a wet glisten. Only one coat was used and applied with a brush. I then moved on to the eyes. I used the tip of a tiny paintbrush lightly dipped in the floor wax and let one tiny drop onto the eyeball, being careful not to let any run out of the eye socket. I repeated the drop process about 10 times on each eye, waiting about 20 minutes between drops, until the eye had a smooth glazed finish. The photos don't show it as well as in the real.
And that is it for the head and neck sub-assembly.
I am VERY pleased with it!
ops::mrgreen:
So, here are the photos of the completed model, so far....
I am still working out my plan of attack on the rest of the model. I am beginning to move away from the idea of making parts removable, as including that with making the internal support structure will cause all sorts of headaches. Besides, if I am going to move in the future or whatever, I will just make a transport crate for it. It is less hassle, I think.
Will be back soon with the next installment, when I work out what that will be ....LOL
