Mr. HAL-9000
micahrogers
3,772
4,639
Shannon GA
Hi everyone my first card model is under way. a suggestion from a fellow card modeler, it's the Mr. HAL-9000 from SF Paper Craft.
printed out on 110# card stock , cut out and starting to form it up. The peices are all jumbled together on my work mat.
Off to a very good start!! Cutting these things up is a thankless job! :)
DanBKing
Dan the Man
Feb 29, 2012
1,817
1,587
Netherlands
But worth the effort in the end!!!
It is very rewarding when it all starts to come together.
In most cases, it is always best to score and fold as much as you can, BEFORE cutting out the final shape.
Looking good!:thumb:
micahrogers
3,772
4,639
Shannon GA
Which brings to mind another question, what should be in a good starter tool kit for paper models?
DanBKing
Dan the Man
Feb 29, 2012
1,817
1,587
Netherlands
These are my most used tools...
You will be suprised what you can find around the house, to aid in paper model building.. :cool:
micahrogers
3,772
4,639
Shannon GA
well... Mr. HAL suffered a Fatal Exception :cry: I printed him an Letter sized paper with the printer set for A4 with scaling active...
looks like I gotta try again
Micah
scyeige
71
In any case, you still can build the one you cut out... the scaling and size will be just off by a little... (more squat).
micahrogers
3,772
4,639
Shannon GA
the pieces were all the right width but a tad to short to make up for the difference between A4 and 8 1/2" X 11" (216 X 279mm)
The PDF is sized for A4.
This pic shows the gap left by the scaling
