Rodger Young Build
roger439
45
Louisiana
Well on the advice of a member here i am starting a new thread on my first large scale build,The Rodger Young. At over 3ft long this doing 2 b quite a challenge.Her r a few pics of progress so far. Sry 4 so many pics.
roger439
45
Louisiana
I hope this is ok to do but here r some more pics...sry for misspelling earlier make sure u test fit before u glue as u can c in pics 4,5,6 i had to do some fixing to make them fit.Thanks to F131 the distance between the long parts is 3 3/8".
roger439
45
Louisiana
and yet some more..sry the pics r out of sync...
roger439
45
Louisiana
I am a pic taking fool...i really hope these help someone else.Well as u can guess here r yet some more.....
anthony344
216
Excellent work roger :thumb: , more pics are better for someone to be building Roger Young as a help line.
Great start, and a picture speaks a thousand words, so don't worry about that. That ruler you are using is too flexible. I have one, and it's great for drawing. You need something very rigid, that will give you better bends.
(text type spelling doesn't work good on forums, yuo aer bettre jsut speleling teh wrod tuo.) :)
F131
F131
Mar 27, 2008
420
4
Minneapolis, MN
Looking good! When it is complete, you will enjoy coming back through the thread and look back at the history of your model in pics.
roger439
45
Louisiana
I use the ruler to guide my knife as a score the bends.It makes the bend easier to do.Thanks for the advice more pics to come.i have got to find a marker to paint in my lines....LOL
You might want to try two different green colored Sharpies, on other combination, to get the color you want. It is amazing how close you can get with the Sharpies, it also adds a neat effect to the edges. :)
F131
F131
Mar 27, 2008
420
4
Minneapolis, MN
Water color paints work well due to filling in the folds, and then can be feathered into the rest of the parts.......try not to feather over portholes.
roger439
45
Louisiana
LOL i have not forgot everyone. It is slow ATM I have the wedge pcs done and working on the LBS pcs. Work has to take priority over play...:( I am building all these pcs before i assemble them for fitting purposes. I will not give up...
anthony344
216
Cannot wait till i see more of your progress , your doing a great job so far roger439.:thumb:
roger439
45
Louisiana
Hi all.... I know it has been a while but camera issues and work has kept me away from the RY. I know it is not perfect but here r some more pics of my progress...hope they help ppl with placement etc.Please note that the wedge shape piece is not glued in place but is generally where it goes.
Take a Sharpie or something to those edges. It will help out a lot, other than that, it's really coming along nice. it will be a beastly sized creature when done! :)
roger439
45
Louisiana
Definitely need to color the lines while i still can get to most of them but what color sharpie do u recommend...I dont think u mean black? thanks for the comments. I am just glad to c it looks like a starship LOL!! I am trying to work on the tunnel a.t.m.I am trying to decide if i want to attempt to cut out the tunnel or leave it white.
F131
F131
Mar 27, 2008
420
4
Minneapolis, MN
Don't use a sharpie. You will have a permanent opps mark when you go off the folds. I used water based paints. You can whipe up excess and feather the color into the parts.
Yes, don't use Sharpies I use them, but only to color a whole part, like an antenna or something. My bad. Water based pain, and you can color match it that way.:eek:ops:
roger439
45
Louisiana
Well confession is gd 4 the soul they say soooooo.. i got over ambitious and already did my folds with a black sharpie.It does not look bad to me i did a fairly gd job on it and i have a steady hand. My camera is charging so i will post a pic of it and let the experts do the deciding after a while.
Anything that breaks the edge is good enough. I remember when I first started out, actually cutting off any protruding white part. From some angles, those models looked great, and they blowed up really good, prodigious use of M-80's! :)
Disclaimer: This forum does not condone or advocate the blowing up of paper models, even if they are not your own.
