Model Of The Month: 1/4 Scale Mercury Capsule: Done 1/1 Scale
PaperAir
941
70
33
66
monson ma
Hi All I,m going to attept Scott,s 1/4 scale Mercury Capsule in 1-1 scale in paper.I,ve gone back and forth with Scott on the sizing I,m getting from my printer and I,m within an inch to true scale.Thats close enough if for me.I will be starting off with the smaller parts of the model and as space opens up for me when I move this spring I,ll get to the main body.The over all size will be 6ft 10 high and 6 ft 2 wide.I started the panel and a simple 1 page is taking on a life of it,s own.Picture 140.jpg
P
Paper Kosmonaut
Incredible! Fantastic! Absurd! Amazing! Unbelievable! erm... errr... Great!
I think you can notice I am quite enthusiastic of what you are building. Like Mike said: Wow.
WeeVikes
23
Miamisburg, Ohio, USA
PaperAir,
How in the WORLD will you resist the temptation to "reinforce" various parts of the model to allow yourself to have your own "procedures trainer"?
If I was building a 1:1 scale model, and I couldn't get in it... Wow, I don't think I could do that!
Mike
ovation
83
38
31
Good luck,this sounds like it'l take a while :thumb:
But it won't be as hard as when you do the Gemini :mrgreen:
JJ-UK
PaperAir
941
70
33
66
monson ma
PaperAir,
Mike
I was thinking of reinforcing the model with resin like they do with halo armor.I know what you mean.
PaperAir
941
70
33
66
monson ma
I had to switch over to the para scope to get the angles right on the control panels.The pictures will get better when I borrow the camera back on monday.01-15-2011 06;25;19PM.jpg
P
Paper Kosmonaut
Wow! When that has got a medium gray spray paint layer it will be very hard to see the difference with the real thing. Amazing!
Mercsim
18
Chandler, AZ USA
Its just a flat aircraft gray. You could probably search the net for some paint colors. Every aircraft cockpit was painted that color in those days.
Here are a few photos. The first two are Freedom 7 (S/N 7). the middle one is from #10. The last two are from #5 (Ham's) Remember it was half full of water when they found it. They also used it later for dozens of ocean recovery tests so it was really exposed more than the others. Hence all the corrosion.... Hope it helps...
I scaled them down to ease up/downloading.
Scott
Nov 29, 2010
276
3
Lakeland Fl.
Excuse my ignorence...I'm not that well versed on the mercury capsule, but what exactly was the telescope used for? I know there was a window in front of the astronaut. Was there some sort of camera mounted inside, maybe for gathering film footage to be sent back to NASA?
