Bomarc
Thanks guys. Always a pleasure when you two drop in.
Yes Elliot, in his early days, Elvis was known to visit the local aircraft plants around Memphis to practice his dance moves with landing gear struts. Years later, Sylvester Stallone would use this same idea for his "Rocky" movie, only there Rocky would visit the local meat packing plant in Philly and practice his punching on sides of beef! True story! Look it up....
If you're referring to this loop (red arrow):
....it's the hydraulic line that supplies the outer brake drum. It snakes through the hollow axle to the inboard brake drum (blue arrow). Then in a "tee" connection moves up the strut into the nacelle:
I don't know if you're aware of it or not, but FYI, the center circular portion (brake assembly) of the wheel is stationary and fixed to the axle/strut assembly. The outer rim (with all the spoke holes) is the only part that actually rotates. This was the standard U.S. bomber wheel rim design, and was used in varying sizes on all the types in service in WWII, from the B-29 down to the A-26 Invader.
I haven't added the brake line as of yet until I figure out how I'm going to fabricate the strut, but the extended hollow tube on my main wheels is part of the "master plan". Now if I only know what that master plan was.....
Incidentally, the second above picture was taken by Dr. William Wolf for his book "B-25 Mitchell: The Ultimate Look" (Schiffer Pub.). Highly recommended, and one of my primary ref's in this odyssey.
Mike
Any idea what the U-shaped metal clip in the middle of the wheel (last picture) was for?
Mike
