Mini Hatak
Status
S
sdk2knbk
I tried to put the model in Downloads, but it didn't seem to work. So, I'll try again here.
Scott K.
  • Mini Hatak.zip
Tars
50
Germany
www.planetstarfreak.de
Cool! At last a Hatak. And one that perfectly fits my current lack of time ;) I was still looking for some nice ship to hang under the lamp in my room, now I found one. And since it's all up at the ceiling, the lack of detail in such a small model doesn't matter at all! Thank you so much :D
Bhelliom
197
5
Parma Center NY
Sdk2knbk used to be me. Not sure what happened to the file, messed up when my old account was deleted? Anyway, I don't have it on the machine I'm using now. I'll have to look for it on my old one later and upload it if I can find it.
Scott K.
Bhelliom
197
5
Parma Center NY
It worked all right for me. IF its ok with our designer, I can send it to anyone who PMs me.
That's ok with me, if you don't mind a bunch of request for it. I was going to suggest that you upload it to the downloads area, but I'd rather wait until I have a better one to put there. I'm on one of my old computers now, and I still haven't found my original copy. It must be on another that no longer has web access (bad modem and i/o card).
Has anyone actually built one yet? I've been meaning to re-work the parts and try to add some proper texture, but havn't had any motivation to do so. I also had a much bigger version in process too (about 4x bigger, and not "hollow" inside).
Scott K.
grifco2000
19
country south australia
Thanks, Bhelliom. I really appreciate you allowing this file to be shared. Hope you get your comp up and running. Im not real flash with them once they die:p I usually give up and send em off to the repair guy (lots of cash later they even come back working sometimes!sign1) Thanks again, Brian:wave:
cmags
28
I just downloaded and opened the zip file above without any problem. I have built this model at a very small scale (about 4-5cm across) just as a filler on a page so as not to waste card stock. Came out pretty cool at the small scale. Not enough detail for a large build I agree, but nice as a mini-model to sit on top of my monitor. :thumb:
lodka
4
as i open th file it myself but the file is invalid or is damaged
you send me by pm
Bhelliom
197
5
Parma Center NY
I wonder what's going on with this? The file size for me is correct, but I still get "The source data stream is corrupt" when I try to open it. This is a bit weird. Why can some download ok and not others?
Ekuth, you there? Any ideas?
Scott K.
Elliott
645
Came through fine for me Scott - correct size and opened up perfectly. Windows XP (all SP's), latest version of Firefox.
cmags
28
Why does a Microsoft product not work correctly on a simple task? You'd be a rich man if you could answer that question. :twisted:
Status
