Tintin Rocket
2Kamser
thanx a lot Charlie :)
This is the one i've been looking foor. Haven't seen it here even though i've been searching for it (maybe did not spell it correctly).
Only problem now is that i'm out of toner in my color laser printer and will be so until end of the month :(, but then i will go for it and perhaps add the LED's to it as well
best regards Håkan
Oliveira
2Kamser, can you please share the uncompressed file with me? I donwnloaded the zip file but it doesn't work. Grrrr... Cheers!
shurricanger
The same with me, I've tried several times to download it, but it always stopped after about 400kb, can somebody help me? Thanks! :cry:
S
SJPONeill
Sometimes you just have to persist with that site - I got it OK but only after a few attempts...very keen to see how the build goes...
D
Diderick A. den Bakker
I contacted the designer directly, and he sent me the files. A terrific model - absolutely wonderful fit. No need to use the complicated compasses cutting method: just scissors worked excellently for me. Planning to build a second version with open hatch and led lighting. Picture on my website www.zeistbouwplaten.nl, Aviation>Space
Diderick A. den Bakker, Holland.
Alcides
Diderick Could be nice to see a bigger picture of your tin-tin rocket.
Can I ask you from where is the model in your site wich the picture is just
above the tin-tin rocket?
Regards
Alcides
Elliott
Sometimes changing browsers solves the download problem. If you are running IE try Firefox or Chrome.
D
Retro rocket; Tintin
Hello Alcides:
I found the retro rocket at the top of the picture while searching for this sort of model via Google Pictures. Then I had to contact the designer, who kindly sent me the files - sorry, I have not made a note of his name. I will send you the material if you like. One drawback to many of these phantasy rockets: no, or only badly fitting formers... an experienced designer friend helped me out.
The thing in the bottom of the picture is a tin toy, based on the same sort of SF book covers of the '50ties.
I have attached a bigger picture of the Tintin rocket for you.
Always interested in more of this type of model! No later than ca. 1970 - I am not into Startrek etc.
regards,
DAdB
There's a link in this thread to another Tintin rocket, complete with LED lighting on this forum. Remembered it from awhile back. Tried to download a couple of times, had a corrupted file. Tried again today, perfect download. Like the idea of mixing paper modeling with simple electronics <G>!
bladix
Wow!!
I was really looking to find a tintin rocket model! I entered the forum just for this I think I'm 9 posts away from access to downloads :D
You can download that model now, bladix. The download rule is just for models we host. That's a very nice model Valmy. The pieces for the pods on the wings have to be cut with a beam compass, I wonder how many left in this generation even know what one is let alone how to use one. I actually have one very similar one shown, it's a Sterret, except mine is around 12" inches long. Nice forum with lots of nice models. Thanks for the link Valmy!! :) :thumb:
