Mini Gundans!!!
SEBRET
nope, the name in the US, is the Strike Freedom, but the actual translation is infinite freedom. The US team than put the show together thought that Infinite sounded to soft, and that strike would be more fitting.
But i hold true to it's real name, the Infinite Freedom
S
Soaring
Great job Tom, I love the concept!
So that's what Infinite Freedom is...I thought it was infinite justice also. :D
tomfogo
Trying to be a designer
this is one of my list to do!!!!
BTW I never heard Infinite Freedom before.... and I think Strike Freedom sounds better!!!! It´s powerfull!!!!!
PS: the mini Strike is done!!! Just have to finish the top of the box!!!! tomorow I will post!!!!
S
Soaring
Great job! What did you use for the "see through" case? Was it just normal plastic packaging, or was it plastic sheets?
René
hello Tomfogo
You did it, and it´s incredible. Thank you for this beautiful model :thumb:
Merry Christmas and a happy new year to you !!!
René
tomfogo
Thanks everybody!! This is a plastic paper, in Brazil it´s called "acetato". In the 80´s and 90´s, this paper was used to make presentations on a light projector.
Grindar
See what happens when I take a break for a month?
Man, your work is amazing. I just tried to print out this guy, gonna have to wait til I go back to work, this printer apparently can't keep up with the awesomeness of your design.
If you're taking requests for ideas for the next one, I have a couple suggestions. First would be the other striker packs (or whatever they called them, been a while since I watched SEED) for the Strike. Those should be a relative minimum of new modelling. Yhe other is the classic rx-78-2. For practical purposes, the zeon suits are all probably too curvy for this scale, but a zaku ii would be uber awesome.
On a side note, did you ever collect the amount you were looking for to release the big aile strike you did?
Keep it up man! I look forward to seeing/building your current and future models!
seth crofton
wow thanks again i have my two boys working on it right now. should we have a contest to see who can re scale this and make the smallest one?
