Frustrations with KATO grab irons
TruckLover
Mack CH613 & 53' Trailer
Apr 14, 2006
4,073
Rancho Santa Margarita, Cali.
Hi Guys, what size drill bit should i use to drill the wholes slightly bigger so that the grabs will actually slide in? Im assembling a KATO SD90/43MAC and the grabs are just a pain in the :curse::curse::curse:
This is the first problem that ive had with assembling an KATO engines, they usually are fairly easy to me, but this one is just so stubborn and i have to order new grabs to now finish the model do to so many being broken or lost.... wall1 wall1 wall1
eightyeightfan1
Now I'm AMP'd
Torrington, Ct.
Just go get yourself some Detail Associates Metal Grabs.
You'll have to touch up paint them, maybe cut them down a little, but I think you'll be plesaed with the results.
When I was assembling my GE C44-9W, I tossed the supplied Katos, and used the DA's.
green_elite_cab
Keep It Moving!
Apr 4, 2005
1,876
Hainesport NJ
Yeah, i had the same problems on my SD80MAC. metal grabs look better, so go with them. I'd almost say just go out and buy brass handrails as well, (I know they sell them for the old RPP SD90/43MACs), because, atleast on my SD80MAC, the corner handrails are seperate (and i think the hood handrails are in two parts as well), and you'll find them to be a MAJOR pain in the @$$. you can glue them but it will still never be as good as a solid part.
toptrain1
940
576
93
New Jersey
Don't get piXXed
It is a hobby. Be cool! Trains are meant to be injoyed. When something got to you as a kid, you would just walk away from it. Come back to it later.
As to whtazzz go'n on. Before I got these metal handrails I would get a 0-60 and 60 to 80 drill bit index's. Also a good push drill that has a very small chuck or better replaceable chuck inserts. Also a pin can be used here. These holes are usually tightest at the opening on top. You need something to ream out the top of the hole. Sometimes all you need is to open the top of the hole by pressing a pin point into it wiggleing it around. Or get a pin slightly wider than the hole and useing it's tapered point to ream open up the hole top. Also put a very small drop of oil on a surface that will not obsorbe it, using your small pin's point weted, ( not a drop ) lube the opening. When this fails you go to the drill bit. Finding one ever so slightly larger. Then drilling it open. Remember those drill bits are small and fragile. They break easily! Their is only one of each size in the index.
Good luck. Take your time.
frank
Fluesheet
339
Central Ohio
IMO, a very useful modeling tool is a dial caliper. In this case, you could use one to measure the grab diameter, which would answer the drill bit size question.
You can find them here and there relatively inexpensively - examples:
http://www.ares-server.com/Ares/Ares.asp?MerchantID=RET01229&Action=Catalog&Type=Product&ID=80973
or
http://www.ares-server.com/Ares/Ares.asp?MerchantID=RET01229&Action=Catalog&Type=Product&ID=82556
Gun shops, Sears and about any other tool shop should carry the lower end calipers - and that's all you need for modeling.
Matt
TruckLover
Apr 14, 2006
4,073
Thanks 88 and Chris for the reply's. When i get some money, im going to buy a bunch of metal grabs and start replacing them when i build kits that require grab irons to be installed. I agree, they look WAY better :mrgreen:
TruckLover
Apr 14, 2006
4,073
frank
Thanks Frank :mrgreen: this advise is something i think some of us forget sometimes. When you get angry or impatient with a kit or whatever your working on, if you keep going its only going to get worse :eek: :rolleyes: Last nigth after i posted this thread, i packed up the engine before i broke or lost any more grabs, then continued this morning after i had slept off all my frustrations LOL. Well in the end, i just barely had enough grabs to finish the engine off, and i only had to use one grab iron that was not supposed to go in that spot, but i made it work anyways and you cannot even tell lol the extra grab was left over and was not going to be used on the loco.
Come to find out, i found a sorta U shaped pin in the kit, and in the directions, it says that you can use it to "open" up the wholes before sticking the grabs in. I took a pair of needle nose plyers and opened up the wholes with the pin and sure enough, that was all it needed. This along with a better attitude got the job done :mrgreen: :mrgreen: guess this is another example where reading pays lol
TruckLover
Apr 14, 2006
4,073
or
Matt
Thanks Matt, i actually have a high end dial caliper that my grandpa gave to me, i always forget i have it LOL. Thanks for the tip :mrgreen: :mrgreen:
green_elite_cab
Keep It Moving!
Apr 4, 2005
1,876
Hainesport NJ
do you have a pinvise set? i have a little metal case that has various sizes from what i think is #60 to #80, and then i have a secondary set that has some doubles of the first, and larger ones in the #50s range.
toptrain1
940
576
93
New Jersey
JOSH : Job well done !
Josh : This is a cool hobby. You are a locomotive engineer running a train up and down grade thro turns and long straight aways. A craftsmen assembling and custom detailing your equipment to your railroads standards. You design and build your railroad. Track work, structures, scenery, & wireing. It is like you get to build your own world, active but peacefull. And you get to share ti will others. I like this hobby !
frank
TruckLover
Apr 14, 2006
4,073
I do have a pin vise with a couple sizes of bits i got from Walthers. I need to order a set of them though and get a few extras in a couple of the most common used sizes
TruckLover
Apr 14, 2006
4,073
frank
Thank-you Frank :mrgreen: those are some GREAT points as to why this hobby is so AMAZING :thumb: :mrgreen:
TruckLover
Apr 14, 2006
4,073
I got a new sd70mac from a co-worker and found they wernt to bad to deal with considering i only lost 2 grab irons. Yet i did feel some of your frustrations Trucklover.
Ive done grabs on 3 KATO SD70MAC's and never had problems with them either, i member when i did my other UP SD90/43MAC last year, it did give me a tough time on a couple holes but nothing like this one did lol. This one just needed all the holes opened up :mrgreen: :thumb: little to much factory paint i guess lol
wjstix
212
I just use a sharp X-acto knife. Stick the point in the hole and rotate it 360 degrees a time or two. It usually does the trick, allows you to put the handrail in place but leaves the hole small enough that the handrail stays in place without needing to be glued in.
TruckLover
Apr 14, 2006
4,073
Thanks for the advise Stix. When i use a hobby knife, i usually over due it and open it up to much :eek:ops: wall1 LOL guess i should just rotate it one time and then test fit it :thumb:
