Removing glued down flex track
RobL
29
Hamburg, NY
My Uncle is in the process of getting out of the hobby and has a very large layout with flex track that was glued down. He has offered the track to me, which has to be in the range of well over 500 linear feet as well as a ton of switches.
Does anyone have any secret recipe for removing track that has been glued down without causing damage?
This will save me a ton of $$$ if I am able to recycle and reuse his old track if it would be possible to remove it from the board easily.
Thanks,
--Rob.
Fluesheet
339
Central Ohio
Thanks,
--Rob.
Rob, do you know what kind of glue was used? Is the flex track fiber ties or plastic? What kind of material is it glued to?
Matt
RobL
29
Hamburg, NY
Matt:
The track is Atlas code 100, plastic ties. It was glued down with a diluted Elmers glue and water mix to homosote board.
Thanks,
--Rob.
Nomad
1,570
Elks Plain, Washington
Matt:
Thanks,
--Rob.
Elmers glue is not waterproof. Soak it real good with water and it should come right up. Worked great for me when i removed my ballasted track.
Loren
seanm
358
Sunny CA
www.pegnsean.net
Lay paper towels over the track and then pour water on them. Let them soak and keep them wet for a day or so.. keep checking and eventually the track will come up. This only works for elmers white glue.
RobL
29
Hamburg, NY
Thanks for the advice guys!! Reusing that much track should save me some significant dollars that I can put into other parts of the layout...
I was expecting to have to create some oddball concoction of chemicals to remove the glue... thankfully good old H2O should do trick!
Thanks again!
--Rob.
