chains on trucks?
N
nachoman
I have noticed that many steam engine tenders and passenger cars have short lengths of chain joining the truck sideframes to the car body. I guess I have always noticed them, but today I got to thinking why they are there. Does anyone know why? And why not on standard freight cars? Obviously, they limit the swing of the truck, but in what circumstances would the truck swing too far?
Kevin
UP SD40-2
2,709
Kevin:wav: , as i understood it, the chains are there for two reasons, to keep the trucks with the car in the event of an accident, so the trucks don't roll away, or go flying off doing damage to anything nearby:winki: .
for some odd reason if the car ran aground, etc., to keep it up in a "jackknife" situation.
EDIT: you have a good question:thumb: , DON'T take my answer to the bank though, the info i gave you was passed on to me, i could have been misinformed:eeki: , lets see what other folks say, i am curious.
:deano: -Deano
N
nachoman
this is kinda what I was thinking, but why only on tenders and passenger cars? Human safety for some reason?
Kevin
logicman
Greybeard
Apr 30, 2008
275
Kent, UK.
Hi, all.
In the UK, these safety chains were fitted up to about 1920s on tenders, passenger stock and luggage vans. They were 'breakaway' chains - a fail-safe device - as used on the highways, on trailers.
Our screw and chain type couplings reduced discomfort by keeping stock close-coupled, but apparently, early examples were prone to fail. It's linked to the reasons behind the red light on the rear of the train - if you're a signalman, and you see a loco and 20 wagons roll by with no rear red light -
you can reliably expect another 20 wagons to roll by shortly!
Safety chains keep signalmen's heart rates within the specified safety levels.
:wave:
doctorwayne
3,516
Canada, eh?
Kevin
As Deano said, it's to keep the trucks with the car in the event of a derailment. Rail cars simply sit on their trucks (there's no giant screw holding the truck in place) ;): the chains prevent the trucks from separating from one car and ending up hitting another, causing even more damage and injuries
Wayne
N
nachoman
So, in the event of a derailment on passenger trains and tenders, the chains keep the truck from flying off and smashing into another car or the loco cab, thus reducing injuries. I guess that makes sense.
Kevin
logicman
Greybeard
Apr 30, 2008
275
Kent, UK.
Ah! I'm sure you can hear the sound of the penny dropping, all the way across the pond!
So, ingrish 101: 'truck' = 'the bit with wheels on', not 'the whole darn wagon'?
sign1
(Need more coffee.)
:wave:
bigsteel
Call me Mr.Tinkertrain
Dec 12, 2006
1,319
Cincinnati,Ohio
so,if a pin is the only thing holding a truck on how do regular freight car trucks keep from flying off in a collision without the chains?--josh
doctorwayne
3,516
Canada, eh?
They don't - in a wreck, they're all over the landscape. :eek:;):-D
Wayne
4,501
Lakewood, Ca.
Josh, I think the issue is safety for people rather than a concern that the trucks are somehow tied to the car. The chains are used on the locomotives and passenger cars because both are occupied by people who could be injured or killed by flying trucks. Nothing keeps the freight car trucks from flying off because there is generally no one around when a freight car derails.
logicman
Greybeard
Apr 30, 2008
275
Kent, UK.
Thanks, Charlie.
No, I didn't know that. It makes your merry jest even funnier.:thumb::thumb:
All I know about tornados is that the RAF used to own a few.
:wave:
railwaybob
419
Ottawa, Ont
www.railwaybob.com
If you ever see a train derailment on television in North America (can't speak for the rest of the world) you will see wheelsets all over the place. Your first comment will be "where in the world did all of those wheels come from?"
Next time you see a freight train roll by, take a look at what's holding the axles in place. With the advent of the roller bearing wheelset, it's simply the weight of the car on the side bolsters that keeps the wheelsets in place.
So, when the car(s) tip over on their sides, the wheelsets come loose and continue rolling down the tracks. The first thing that the rescue gang do is move all of those wheelsets off to the side of the track so that they can move their rescue equipment in.
In most cases, the old-fashioned railway crane has been replaced by "side-booms" - the kind you see in pipeline construction - and power shovels. The side-booms are used to either put the car back on the tracks or to move it out of the way. The power shovels have a special attachment where the bucket usually is. Flat-bed trucks come in with "snap track" which the power shovels off load and walk down the side of the track with a piece of "snap track" hanging from the end of their boom. The damaged track is simply cut out and moved to the side. Pieces of snap track are used to rebuild the track.
This opens up the mainline pretty fast and the clean-up crews can do their job at their leisure - provided there are no haz-mat spills.
Bob M.
