M4a3 Sherman - Gpm
Status
charliec
384
Brisbane, Australia
The GPM tracks aren't very realistic - but you've managed to do a great job with them. Most WW2 US tanks used a rubber block track (M4 Sherman Tank) which aren't easy to model in card. You might like to look at the Gremir M3 builds over at papermodelers.com for another take on US tank tracks.
Regards,
Charlie
M
Mark_1984
Great job - It's the tracks that put me off doing a tank. I just wouldn't have the patience to cut out so many identical parts. Yours look very realistic.
S
Soaring
Wow, that Sherman you have there looks excellent! The Tracks especially, I can't wait to see the rest of this Sherman :)
Patty
King of Swaziland
May 13, 2008
10
WOW!!! This is looking NICE. I hope the rest of build is as fast and easy as this part.
Stev0
626
So far I have seen countless armor threads die at the track stage.
Good to see that you have pressed on.
As to the off color edging... You think 'brown' or 'tank' ink to those green areas would turn them down?
exzealot
142
Lake Orion, MI
To all,
Thanks for the encouragement! I finished some of the front ornaments and their metal guards. These are the time-consuming details, but also the most fun.
Note that I tried to tone-down the edges a bit by using OD green paint. Still not exact, but a lot better. I have a plastic model of an American WWII tank, and the instructions call for Olive Drab. This model is something a little different - can't quite figure it out.
Ken
logicman
Greybeard
Apr 30, 2008
275
Kent, UK.
Nice build.:thumb::thumb::thumb:
You have a lot of patience.
As for the colors, I like them. On my monitor this lot shows as brown with a green highlight to edges. That's the sort of thing a museum of engineering might do, to emphasise the working components. Red is more common, especially on cutaways, but for me, those colors suit the model.
:wave:
Stev0
626
It's funny because I am building Nobi's Cromwell and it's roughly the same color base as your overall sherman and the edge coloring is the exact same.
The turret is going to be interesting. I want to get this kit.
exzealot
142
Lake Orion, MI
This picture shows the installation of (what appears to be) a towbar on the front face of the tank. The model was designed for wire hinges on the bar, but I built mine the easy way out - I glued it permanently in place.
Also note the machine gun in the front. Again, the complexity and work required to make the gun moveable is not worth it to me, so I glued it stationary.
Please forgive me!
Ken
exzealot
142
Lake Orion, MI
Small progress, but this picture shows the top covers for the front crew hatches. The model was designed so that the entire lid can lift up - many parts provided for this feature. However, the instructions were extremely vague in describing the build, so again, I glued everything down in a closed position. My plan is to have the two hatch doors open and close.
Ken
charliec
384
Brisbane, Australia
I think you mean the travel lock for the gun. The idea is to support and lock the gun barrel so the breech mechanism won't move around when being transported.
The tow shackle points on the Sherman are low on the hull beside the brake housings (see image)
I should point out that the Sherman in the image is fitted with a 76mm gun rather than the 75mm of the GPM model. The 76mm gun barrel was longer so the travel lock clamps the barrel further out from the turret than the 75mm so the legs of the lock are a bit longer than the 75mm version.
Regards,
Charlie
Patty
King of Swaziland
May 13, 2008
10
About the tracks: "these are the times that try mens souls..."- need I qoute from where that came from? The tank is nice, but looks aren't everything...
exzealot
142
Lake Orion, MI
Charlie,
Thanks for the explanation and the pictures. Makes sense! As you can see, I am not an expert in tanks; but thanks to some of you, I am learning as I build.
Thanks,
Ken
S
Soaring
Hey, Kenlwest, you did an exdcellent job with the hull of the tank. The little details looks so realistic!
On the note of creating the open features on the lids, I believe you use copperwire through some holes :/
To get a better look at it, I guess you could go onto Picasa web albums, type in M4A3 Sherman, and there should be some build pictures of the same Sherman you're building. In his album about the Sherman, there's one bit that shows the lids open and close feature up close, I guess it could be used as a reference.
cdavenport
167
Athens,Georgia
Welds
Tanks are a subject where seams are good. Most of those seams are welds. Here's a tip for recreating welds. I suggest you try it on scrap first. You need some plastic sprue and a low temp soldering iron.
Yu will need to stretch the sprue to obtain a diameter that is consistent with the seam you wish to replicate.
Glue the sprue in place and trim to size. Use plastic tube glue for this. It will seep into the paper and bond plastic to paper.
Use the soldering iron to simulate weld beads by pressing the tip of the iron into the plastic and giving a gentle nudge. Repeating this with a measured sequence along the sprue makes it look amazingly like a weldment.
If you are unclear about any of this, let me know and I will shoot some photos or an mpeg so you can see the process.
It really is very simple and worth the effort....especially if you are going to show with the plastics guys. I know; I'm one of them. I am working on my card Hunley to compete against the plastic ships. It takes some effort.
Status
