galaxy and majestic
Status
wlock
149
Geneva
The files are getting big for a paper model and the PDF are even bigger so i think i'll accept your offer once it's done. the neck section is still a problem and i have to figure out a way to make warp drives that are not too hard to build. i'm sending the PDO file to those that are testing the saucer and hopefully the comments i get back will help solve the remaining problems
thank you all for your comments!!!
S
Starship Builder
thank ive got it ill be starting soon just my ink ran out at the last minute the model looks great
jleslie48
96
Aimont, NY
Sounds great. Whenever you are ready to release it, just get me the release files in any format that you like.
col. kurtz
104
2
basildon,essex u.k
i was the othger person wlaock sen the files to :thumb:ive started the beta build cut out all of the saucer sections and im about to start assembly..ill update with photos abit later on :thumb:
col. kurtz
104
2
basildon,essex u.k
hi there heres photos of how im getting on with the galaxy.i printed the pages two to one a4 sheet instead of single pages.:thumb:
col. kurtz
104
2
basildon,essex u.k
more pics
col. kurtz
104
2
basildon,essex u.k
last set of pics.just to let you guys know i havent bothered to colour the edges on the parts to make it easier to see the construction:thumb:
wlock
149
Geneva
Here's how he warp drives are going, the 3d model is quite simple and looks great with textures but when i start working on it in papekura it just breaks into small pieces, i'll probably have to redo that midsection.wall1
wlock
149
Geneva
wanted to show the progress on the 3d model so far, i've highlighted the construction lines. the saucer itself hat to be modified to fit the neck section as you can see in one picture. not sure how the lower part of the secondary hull will be on papekura, that's likely to change.
wlock
149
Geneva
last pics
wlock
149
Geneva
Actually yes, i am planning on making several textures for the galaxy.
I need to find the right fonts for that.
When i print from papekura the texture quality is not as good as the original so i'll redo the text on photoshop. changing the name is just a step away.take a look at the screenshots
the second image is nearly 20 meg in bmp format, this is going to be a big download......
Anybody knows where i can find the fonts they use for the federation?
Status
