model railroader 2005 carolina central article
trainman111
2
Can someone scan the model railroader 2005 carolina central article titled More action on the Carolina Central on page 84 and post or email to me? I have purchased the original n scale getting started book and want to see the chnages they made. Any help would be appreciated.
Thanks in advance
kpoole
32
MR 2005 Carolina Central
See my reply in the Nscale.net forums about scanning. The issue is still available for purchase through Kalmbach (which I just did). A wye is formed on the right side of the layout, connecting to a narrow shelf containing a staging yard. Connections are made to the front of the curve, behind the existing turnout for the passing siding, and to the rear of the curve, into the hidden staging.
trainman111
2
ordered
Thanks. I did not realize the publication was still available. I just purchased directly from Kalmbach Publishing, so I am all set.
kpoole
32
Mr 2005
Good to hear. The issue overall isn't bad (I purchased it for the same article). I'm in the process of building the Carolina Central as well. For what it's worth, I believe there are back issues available for several years back.
kpoole
32
Scanning Articles
Ron,
That's between you and the wall, if you're ok doing that. I've also come around to the issues of "backing up" CDs and DVDs. I'm sure someone else will chime in on possible copyright issues as well, but I've said mine.... He has already ordered the issue, so the topic has been resolved anyway.
MasonJar
It's not rocket surgery
Oct 31, 2002
5,362
Ottawa, Canada
RE: copy/backup
The other difference is that once you've sent your copy to him, you still retain the original. So the publisher missed out on the chance to sell another copy of their material.
Backup is a little different. Assuming that you are not using both copies at once (i.e. on a CD player at home, and another in your car), the backup enables you to continue to use the material that you purchased.
Many of the drawings in MR carry the statement/release that the purchaser can make copies for his own use (presumably so you don't have to chop up the magazine). However, this does not extend to making copies for someone else, due to the reason in my opening paragraph.
Andrew
MasonJar
Oct 31, 2002
5,362
Ottawa, Canada
Sorry Ron,
I just reread - if you mean that you send the original ("my copy"), then there is no problem. If you make a photocopy or other duplicate, then there's technically a problem, whether money is exchanged or not.
Andrew
