Window glazing?
N
nachoman
I use clear plastic that comes as packaging for many items. i cut it to size with scissors, and glue it to the back of the window with white glue. I use white glue because it won't frost the plastic.
Kevin
steamhead
2,360
Brownsville, TX
Hi...I use the clear acetate that comes with the kits, but these suggestions would work OK too. I buff one of the sides with steel wool to avoid that see-right-through look. Since most of my buildings and some cabeese are lighted, this gives a nice even glow to the light. I place the buffed side to the outside. Good luck..!!
Nomad
1,570
Elks Plain, Washington
If you want a dirty, dusty look, you can use wax paper glued on with Aileen's tacky glue or the like. If you carefully scrape the "windshield" with a razor blade using a circular motion, you can simulate where the wipers scrape.
Loren
bigsteel
Call me Mr.Tinkertrain
Dec 12, 2006
1,319
Cincinnati,Ohio
Loren
i use a slightly more complex way but get the same results.you mask an area the wiper would normally contact then dulcoat the window giving it a dusty look but lorens would work well also.--josh
eightyeightfan1
Now I'm AMP'd
Torrington, Ct.
Using Evergreen .010" clear styrene works good. You can cut it with scissors. I know Athearns Blue Box cabooses came without glazing, which means having to cut window glazing.
Or depending on the MFG, order a new set.
doctorwayne
3,516
Canada, eh?
I'd go with the .010" styrene, too. It's easy to cut, and can be fastened in place with your usual styrene cement. Acetate is difficult to keep glued in place over time, and it will also yellow as it ages.
Wayne
nkp174
1,455
Cincinnati, O.
I use evergreen's clear styrene. Commonly 0.005" and 0.010" thick.
The other classic way is microscope slide cover glass. It won't fog up like the plastics do if you mess up...and paint can be scraped off. I'd use it for any permanent windows that aren't removable...or if I had enough room for its thickness (since I like 0.005" to slide into scale window frames)
