Some basic truths I learned wiring feeders
Renovo PPR
Just a Farmer
Dec 23, 2006
544
Somerset County PA
When it comes to animals Doc your at a disadvantage. While I'm not claiming to be an expert I will claim actual experience:rolleyes:.
I have 150 beef cattle, 5 goats, 15 hogs, 15 cats, 1 turtle and two dogs. I will not claim the cattle are smart but they are the most trainable. The cats work the hardest keeping the rats in check plus they and the goats love attention and actually are pretty good at keeping the calves in the pasture. Well the turtle and dogs don't do much except lay around and eat.
A special note a cat will turn tail on a skunk. A dog will force you to find new ways to get the stink out of the fur. I guess they think the skunk is a new toy just like they thought the hot iron was a bone.sign1
nkp174
1,455
Cincinnati, O.
hey has anyone evertried one of those "cold heat" models, I had one for a little while, but couldnt get good results out of it........
Mine worked crapily. It's essentially the same thing as a resistance soldering unit...it passes current through the joint...but not enough to adequately heat it up and melt the solder. I'm sure it works for some small applications.
Today I watched as both of my cats not only avoided the hot iron...but its cord too. I was soldering temporary jumpers to my new On3 empire...75% of a loop completed...a 2-way and a 3-way stub switch...plus a y. I was soldering jumpers around the turnouts...next time I'm going to use PC board ties on complex turnouts. The 3-way was a nightmare.
who_dat73
330
Minnesota
when I first started MRRing I heard about this whole soldering thing so I grabbed the pipe solder out in the garage coulding figure out how to keep from melting ties and wire insulation till I went to RS and foud there was smaller solder to be had for just such applications wall1
