Some basic truths I learned wiring feeders
eve_9d9
70
Bowling Green, Ohio
Im in the depths of wiring a buss line and feeders at the moment (actually taking a break right now) and figured Id share my experiences, so here they are....
1. the day after you spend a fortune on copper wire for your buss, youll find some in the garbage at work that would have worked just as well
2. soldering a wire the diameter of a human hair to a 1:160 scale length of track with 1:1 scale soldering iron is the the most frustrating thing a human can do
3. dont check if your soldering iron is getting hot by grabbing it between your fingers real quick......you can be the fastest person on the planet, youre still getting burned...
4. run your feeders before you ballast the track.....
Im sure there are more of these to come.....stay tuned and pray for me......
N
nachoman
#1 is definitely true. I come across free scraps of wire between 1-2 feet long all the time.
Kevin
nkp174
1,455
Cincinnati, O.
Never solder under the layout with shorts on....wall1
My parents cats used to chew the wires under the layout...
my parents could always tell when I was soldering by the "OUCH!"s coming from under the layout. That was before I learned how to solder properly.
How do it correctly? Pick up flux and solder...and use a soldering iron...not a gun. Apply flux to the wire and the rail. Heat up the wire until touching it with the solder causes the solder to flow onto the wire. Next, heat up both the wire and the rail at the spot where you will be soldering...and the solder will then flow from the wire onto both. You don't generate enough extra molten solder to cause the dreaded drops of molten solder. :p
RailRon
1,602
Trimbach, Switzerland
Of course you know where you just put down your soldering iron. But never pick up a hot iron without SHARPLY LOOKING AT IT!
Invariably you will grab the iron at the wrong end! :eek::curse:...
:mrgreen::mrgreen::mrgreen:
Ron
nkp174
1,455
Cincinnati, O.
Leaving your hot iron on the floor and having your dog thinking it is a new toy. I did this one.
Wow! I've always been concerned about my cats doing that...but they're generally good about avoiding hot things...still, I could see them accidentally doing that.
doctorwayne
3,516
Canada, eh?
The problem is a dog is not as smart as a cat. The cat will check it out first. The dog will just pick it up then figure out what he has after the fact.
Actually, when the cat realises that the soldering iron is a tool, and therefore somehow related to useful work, it avoids it. ;) Most dogs, on the other hand, know how to solder, but they're lacking that all-important opposable thumb. Still, they remain eager to help. :-D
Wayne
Gary S.
1,576
Texas
:mrgreen:Very nice, DocWayne!:mrgreen:
