Athearn Aniversary Cars
CNWman
CNW Fan
Jan 3, 2007
1,268
The Riverside Railroad
Hi all:wave:
I'm thinking about getting the Athearn aniversary boxcar and observation car, but there's one thing I don't know: can the observation car take 18 in. curves? I don't want to order it only to find it won't take my curves. Here's the link to the aniversary stuff: Athearn - Product Search
jesso
702
Washington, Utah
www.thetechfamily.com
My full-size IHC passenger cars get parked on a 15" radius curve (yes, I know, don't flame me) and they don't derail. However, they have truck mounted couplers where the Athearn one looks like it has body mounts, so that can be one difference.
CNWman
CNW Fan
Jan 3, 2007
1,268
True, but the couplers issue can be dealt with, my main worry is the 6-axle trucks and their ability to handle my 18 in curves. Athearn also seems to have four-axle trucks for these cars, but I only have one Athearn car, my NMRA Convention special hopper.
4,501
Lakewood, Ca.
Athearn passenger cars are called "shorty" because they scale out to72 scale feet long instead of 89. They will take an 18 inch radius curve, because the couplers are truck mounted if I remember correctly. If they aren't truck mounted, they are mounted on long swinging arms to allow them to handle the tight radius curves.
Kanawha
262
Glendale, AZ
I have curves between 15" and 20" in radius on my layout (space limitations) but I've been running 85' boxcars and 6 axle engines for years. Rarely do I have a derailment. However, I have to admit my longer rolling stock looks pretty silly on the 15" areas. :eek:ops: :mrgreen:
CNWman
CNW Fan
Jan 3, 2007
1,268
Ah, thanks Russ, that clears things up. You're probably right for the coupler arms, for the observation couplers don't look truck mounted. If they can take 18 in., then I will be getting one:mrgreen:
brakie
2,827
Bucyrus,Ohio
Russ,There are prototypes for those cars..You see the 72 footers was use on second and third class trains.Even the C&O had some 72 footers.
4,501
Lakewood, Ca.
Thanks for the info, Brakie. I knew the old wooden cars from the 1800's were shorter, and I knew about the 30 footers that the Sierra RR had specially made that were the prototype for MDC's Overton cars; but I didn't know that modern cars were built shorter than 89 feet.
nkp174
1,455
Cincinnati, O.
Actually, the standard length of passenger cars was 85'. This was almost universal in the lightweight car era (1938+). This was also common in the heavyweight era (1910's-1930's)...but many heavyweights were also built to lengths such as 70', 75', and 80'. The only wooden cars that I can think of being 80' long were a set of Pullman demonstrators build around 1905 or so...I don't feel like checking my reference books for an accurate number.
The only real concerns with derailments are weight and how far from the trucks the couplers are mounted. Athearns were designed in...50's or 60's...when 18" seemed to be more common.
Athearn's shorties are for people whom hate the overhang that scale length cars have on tight curves...with the downside...especially for their lightweight cars...that they look downright ridiculous to some people...such as myself. Different people care about different details correct...and no one can get eveything correct as we have to exercise selective compression...I care more about cars & engines than the track. Athearn's heavyweights are more believable since there were prototypes for them. The headend cars are also more believable since headend cars were usually shorter. I can say with a very high degree of confidence that any 72' coaches or sleepers in the lightweight era were rebuilt from earlier cars and wouldn't look like the Athearn cars (see the B&O's rebuilt cars or the NKP's 80 series coaches). The rebuilt cars were usually riveted like the heavyweights...but with rounded roofs and lightweight style windows...
I think I'm ranting...so I better stop...
The Athearn cars are fine for 18" radius. I would go ahead and order the car if you'd like it. Just check to be sure that the wheels are in gauge...and you'll be happy with it.
