Dave Harris
Going thru some old catalogs I had that I had stumbled across while searching for part of my Unimat lathe in my storage area, I found the catalog for Micro Fasteners . It was from 1996 , at the time they had no web site , I did a search & sure enough now they have one.
Amazingly their prices have not changed a bit in 11 years!! If you need some small screws for your scratch projects this is a great place to get them-- far better than Hobbits & walthers at 3.00 a dozen. Example ---I bought 0-80 X 1 inch round brass screws 4.40 a HUNDRED !!! 00-90 are a bit more--- 6.00 for 50 ---- I buy the longest size & cut them to length. I have several pieces of brass of various thickness with threaded holes , I put the screw in the one that has the length I need , cut if off with a cut offdisc & when you back it out it straightens out the threads so they will work again.
So if any one needs fasteners you might take a look here
Micro Fasteners - Hobbyists Source - Locknuts - Washers - Machine Screws - Fasteners - Rivets - Wood Screws Another nice feature is that they have no minimum order .
They also carry stainless & allen screws in at least 0-80 possibly smaller .
