trainsteve2435
Hello everyone, my friend just gave me a C&O 2-8-4 brass steamer made by Olympia. Does anyone know of this importer? Are they worth anything? Where can i find any information on this model? Thanks!
thanks evryone for your input, and yes Wayne, it is worth quite a bit. Also, it does run very good, it even has a flickering where the fire box is, but its from a dirty motor, but it still looks like a flickering fire box. I guess i have a piece of past history so i will put it up on my shelf. thanks!:thumb:
Russ, i know what you mean, but im not into steam and plus, i run DCC and the tender wants to short when it runs accross a switch. I just figured i would put it up instead of going through the trouble of equipping it with DCC. But i do believe.... if you have em,... run em! Thanks!
I'm not that familiar with DCC, but wouldn't it be simpler to isolate the motor electrically? Then all you'd need to do is run a wire from the loco frame to the decoder, another from the tender pick-ups to the decoder, and two wires from the decoder to the motor. Maybe replace the metal drawbar with a non-conductive one, too. Or am I missin' sumthin' else?
Wayne
I think the draw bar should already be nonconductive. Generally speaking the tender frame is the opposite polarity from the locomotive frame. Just insulate the motor from the frame and wire in the decoder.
