Cannonball
More Trains Than Brains
My track is getting gunked up with glue and such from building the layout. What are my best options for cleaning it?
This is probably a first.
I've tried alcohol and all those expensive "miracle" track fluids.
The best thing I have found thats works like magic is a product called "butch's bore shine". You can get it al your local gun shop.
It's great for removing anything from the track and it polishes it really great. The solvent won't damage your plastic or landscape.
Before you do more plaster or glue work around your layout, apply masking tape over the track. Keeps all that junk off of them :mrgreen:
For crazy glue or hard like things I use a woman nail file. You know that ones made of stiff paper that have a rough and a fine side? Well I use the fine side for the rail.
I also use the nail files for my scratch building models as well. They make great sandpaper substitutes
I hope that helps.
I can only recommend, from my one experience, that you should consider not using anything that will scratch the track. A scratched track attracts dirt and grim buildup. Bright boy scratches the track. I use rubbing alcohol, on a clean cloth, to clean the track. I then coat the track with a extremely light of "NO-OX-ID" that prevent s rust and grim build up on the track. One year of service on the track and no cleaning has been required. Check out Sanchem.com or a general search for the product. It works.
