Lord Raffles
Does anyone know the size each support should go up by and what distance apart they should be from one another?
Thanks.
Thanks.
I think I know what your saying now, are you going to be using something like this:
These are made by Atlas and they start out at ground level and work there way up and then back down again to ground level. Is this the kinda thing you are talking about doing?
okay I gotcha now, well I cant help you with that part lol. I havn't the slightest idea for the height and the distance each pier should be spaced, sorry. The hight is going to depend on how high you want to go in the planned distance you have/want (member you have to go up and then back down in that distance).
Do you know how long you want this to be? like how many inches or feet will this span, this might help someone in answering your question about the hight and distances.
Maybe not... British N is 1/144, not 1/160. Test with the engines and rolling stock you have.If you're modelling Welsh steam, I think the locos would generally be even smaller, so we're talking about 1 1/4" clearance if you need to be able to run a loco beneath the elevated section of the track.
