Turnout radius?
rogerw
1,110
manhattan ks
I did a search on this and found out according to nmra that #4 is about a 18", #6 about a 22". Is a # 8 about a 26 " radius? I would make sense but want to be sure.
rogerw
1,110
manhattan ks
Thanks sumpter the page I found at the nmra site only used the #4,#6 on the page when they discussed turnout radius . just making sure.
Torpedo
278
I found these in John Armstrong's "Track Planning For Realistic Operation" for HO.
#4 15" RCR, 29" SR
#6 43" RCR, 56" SR
#8 67" RCR, 110" SR
Where RCR is the radius of the closure rail (the sharpest radius in the turnout), and SR is the substitution radius for fitting the turnout into a curve.
Hope this helps.
Torpedo
278
The Armstrong book is considered the bible of track planning. He goes into considerable detail in this area (too much for me to repeat verbatim), but these are the numbers he came up with after years of track planning experience.
A lot of people recommend "Track Planning For Realistic Operation" for anyone designing a layout. Personally, I think it is the single most valuable MRR publication out there, regardless of price.
rogerw
1,110
manhattan ks
I guess what im wondering then if im using a 30" radius on my main line and I put some #6 turnouts for branches it wont lower my min. radius of 30 " through the curved part of turnout?
Torpedo
278
Not according to Armstrong. He says that you can even use a #4.5 with up to 30" radius curves.
#4.5 22" RCR, 36" SR
#5 26" RCR, 44" SR
Basically, he argues that #6 and #8 turnouts are space wasters on model railroads, especially with radii of 24" or less. Other than the comment regarding #4.5 turnouts and 30" radius, he really doesn't address broad curves (his definition of 30" radius and greater in HO) directly.
His most basic point seems to be this: The radius of the closure rail (RCR) will affect how "stiff" eqipment like steam locos will negotiate the turnout, and the substitution radius (SR) will affect the train as a whole.
BTW, he argues for laying your own track and building curved turnouts when needed. He diagrams how that saves space.
He does argue for higher numbered turnouts in reverse (S) curves for other reasons, which he discusses at length in another section of the book.
4,501
Lakewood, Ca.
You are correct. At the modular club I belong to in ho scale the club standards call for a minimum 36 inch radius on mainlines and minimum #6 for any turnout coming off of the mainline whether a crossover or onto a siding.
