Liebherr R-954 Excavator by nosports and Retunga
Boris
Hello everybody
It has been a lot of time since I published on this forum.
Just began the Liebherr digger designed by nosports (Chriess) and Retunga
The design is interesting. No cardboard is supposed to be used and according to instruction paper heavier than 80 gsm should be used. This brings to using internal reinforcements and complicates 20190405_235547-800x450.jpg 20190406_001335-800x450.jpg 20190406_024548-800x450.jpg 20190406_043331-800x450.jpg 20190406_043350-800x450.jpg 20190406_050001-800x450.jpg 20190406_050136-800x450.jpg 20190409_001900-800x450.jpg 20190409_023648-800x450.jpg 20190414_011836-800x450.jpg the build. I will use the 145 g/m2 paper.
All in all, the model looks impressive with working boom and swiveling body.
The instruction is an overwhelming 70 pages booklet with explanations and pictures.
So first, according to instruction, need to assemble the inner part of the swivel joint and mount it on main chassis. Then need to make and install outer part of swivel joint. Then I installed outer cover and made a locking mechanism
Afterwards I started with parts of the tracks bases
Looks good for now, except that I made a mistake in making body slopes above the tracks bases. I will fix it later.
Boris
20190410_235302-800x450.jpg 20190413_004621-800x450.jpg 20190413_004647-800x450.jpg 20190413_030434-800x450.jpg 20190413_141158-800x450.jpg 20190413_144313-800x450.jpg 20190413_144317-800x450.jpg 20190413_144324-800x450.jpg 20190413_145657-800x450.jpg 20190414_034501-800x450.jpg 20190414_121157-800x450.jpg 20190414_132327-800x450.jpg 20190414_134953-800x450.jpg 20190414_135018-800x450.jpg Later I managed to finish the tracks bases, tracks supports and the caterpillar tracks
No serious problem found. Two things made me scratch my head:
1. The round part of the middle section of the tracks base - I could never build it round enough, so I made 1.5 mm cardboard formers of the needed diameter and voila, things look happy
2. The lower support wheels covers. I just could not understand how to mount these. So I separated them from their holding strip and glued to their places on the outside part of the track base
One thing that bothers me - there are no markings of where to install accessories, had to guess.
The tracks are made of ( or off, what's correct?) strips. No special troubles here, just need to be careful.
In all, the parts are large. I never used my 30 cm ruler so much like in this model.
11.5 pages of paper on this substructure- impressive!
9,550
Nice to hear from you. I like models of real objects, and this looks interesting! :)
Reactions: Boris
Dagger
215
456
40
Good start! It will be interesting to continue your work. With a simple (but laborious) extra work the chains can be improved a lot.
Reactions: Boris
9,550
You can always return to the tracks easy enough. :)
Gandolf50
1,332
1,585
96
New Mexico USA
Excellent ...I grabbed this years ago, as it looked like a very detailed, quality model, just have never got around to it, will watch this with interest!
Reactions: Boris
Gandolf50
1,332
1,585
96
New Mexico USA
Oppps ... I was thinking of another model the Liebner L586 Loader HERE and from Liebner Website you can download a PR776
I was beginning to wonder why it wasn't familiar to me ( of course getting to my age, memory tends to go second) I took a look to see if I had some ideas on your questions... oh will still be following!!
Reactions: zathros
9,550
Retunga did a fantastic job on recoloring, and modifying Chriess's' models. (I hope I have that order right). There was someone, can't remember who, but tried to cause a rift between these two fantastic model designers, when in fact there was none. They show how when cooperating, great things come of it. ;)
Reactions: Rhaven Blaack
Boris
9,550
A lot of people build models but are shy of posting them fearing negative remarks, or just don't like posting their builds, suggestions aren't negative, but they must be worded properly, constructively. It's amazing how many people I see log on who have we belonged to this forum for years, but rarely post anything. I guess the just enjoy reading the threads? This forum has one of the nicest groups of people in any forum I have and do belong to. :)
Boris
20190416_005010-1024x576.jpg 20190420_022000-1024x576.jpg 20190420_035309-1024x576.jpg 20190420_041508-1024x576.jpg 20190420_041517-1024x576.jpg Hello all
A small update - Backbone assembly (as the designers call it)
Here I bumped into first problem which was caused by my decision to use thicker paper. Parts 47 and 48 needed to be shortened a bit and the part 47 (internal reinforcement) had to be rearranged. I hope this won't ruin the backbone sturdiness
Reactions: zathros
Dagger
215
456
40
It looks very good.One of the things that I pay more attention is to interpret the best grammage for certain parts.If it is not well specified sometimes is complicated, I had this problem countless times. Today I do not miss so much, it is better to stay Short to exceed. Good progress.
Boris
Well, usually it is pretty simple.
But in this case the designers simply mentioned that paper of density of 80 gram per square meter or higher should be used. So need to adapt certain things to this.
9,550
I've always designed my models with the intent of using 110 lb. card stock. I get confused with all these paper specs, I have no idea what "80 gram per square meter or higher means".
Dagger
215
456
40
As you say, usually and if the designer advises the grammage is easier. But I have found sometimes that some pieces on the same sheet should have another grammage. I have passed that the design recommended paper of 160 / 180grs, and a Small tube is very difficult to shape with that grammage. Another drawback, at least in my country, is the difference in quality between brands, it is often remarkable and in the end you do not really know which is the right one.
