Uhu02 interstellar Endurance
Nando
Designer Extraordinaire
Oct 5, 2006
219
611
91
74
Turin (Italy)
After starting and then hanging out a model of UHU02 ( the Orion III model ), I decided to try again with something simpler, or at least I hope so.
So I started to build the model of the starship protagonist of the movie Interstellar, the Endurance designed by UHU02.
http://uhu02.way-nifty.com/die_eule_der_minerva/045.html
To complicate my life, however, I decided to use, for the first time, a product to protect the colors and to "laminate" the paper and make it more resistant. This of course has led to some adjustments in how I normally cut and bend the parts, and the choice of a more suitable glue (vinyl glue).
I then decided to strictly follow the assembly sequence suggested by the designer, hoping to avoid errors and omissions in a model that is not very simple.
I then started with the realization of the individual modules that make up the ring, also following the suggestions to make the surface more three-dimensional.
Here are some photos of where I am right now.
20180409_152153_27470397768_o.jpg 20180419_100904_40662275585_o.jpg 20180502_175317_28002979178_o.jpg 20180504_164719_40087054860_o.jpg 20180517_163154_28299550428_o.jpg 20180525_165538_27475906637_o.jpg 20180718_143927_41679245470_o.jpg 20180718_144506_29616206368_o.jpg 20180718_194828_43494488441_o.jpg 20180720_120110_29653794278_o.jpg
And then others twelve details, and then others twelve, and then others twelve... :(
Best, Nando :)
9,549
Nice start. One of my favorite movies, and a great model.
9,549
I posted yesterday the "system is temporarily down". It should be fixed soon. ;)
Nando
Oct 5, 2006
219
611
91
74
Turin (Italy)
Another batch of connectors on the tunnel elements: the red group (cupola).
20180723_233600_28710995037_o.jpg 20180725_222910_28751164527_o.jpg 20180725_224519_41831240140_o.jpg 28751558057_702677a5a5_o.jpg
Next the green group
Best, Nando
9,549
Lots of glass in those cupolas. Something that could be greebled, they look great as they are though. You sure know how to make a round part, they look perfect. :)
Gandolf50
1,327
1,576
96
New Mexico USA
That would be cool..with an simple interior view..AND LEDS!! " Great work.. coming along nicely!
Nando
Oct 5, 2006
219
611
91
74
Turin (Italy)
... Are you preparing for some kind of exhibition... I guess ... for next october? ;)
Yes, I'd like to expose the model in the appropriate context ;)
No better name for this model I guess, and I had to apply all my endurance to form all those wheels: I had to trim each disc with his ring, slowly working it with sandpaper.
So the green group is complete.
The blue group is the more complex but luckily I have only four elements.
First the rings, the common part to all the groups, and the cylindrical part that I think is like the PMA (Pressurized Mating Adapter) on the ISS.
Then a sort of collar all around the "PMA", very tricky to cut, fold and glue.
Now, after assembly completed for the blue group, I just have to assemble the individual connectors of the communication tunnel.
Best, Nando :)
Tonino
791
1,775
83
61
Republic of San Marino
www.facebook.com
... I began to think about how to display the model. Any suggestion?
This is an interesting question (and, very often, we ask this one ourselves when it's too late to come back... ;) ).
I think it all depends on how hard is all kept toghether by magnets. How strong is the whole structure once assembled.
Looking at UHU02's photos it seem to be pretty solid but it all depends on the magnets you used for the junctions (if you used magnets... or you are going to paste all definitively?)
Anyway some kind of metal wire passing through the axis of the central element should be the best option to show it, instead of simply stand it on one of the faces like in this image... (not too fascinating...)
You should realize some kind of stand similar to the the sundial you made some time ago... remember?
Obviously, if you plan to do something similar, it will be necessary to strenghten conveniently the element who will suffer the weight of the model... so, after all, the question is not too early...
9,549
Such precise work Nando, wonderful!! :)
Reactions: Nando
Nando
Oct 5, 2006
219
611
91
74
Turin (Italy)
Hi Tonino, I think my neodymium magnets are strong enough and I should not have problems with landers and shuttles. I will also double them as the sensei suggests.
I did some simulation.
Not in scale at the moment, just a visualization. Which one do you prefer? I prefer the first one, the simplest. In this case the ship leans on the engine modules.
Best, Nando:)
thegreek270
211
478
41
Greece
I agree with DJPinter.
I too would go with #3. Perhaps if you use the same material as the Background you could make it almost invisible.
Very nice work by the way. keep it up.
