» Less advertising throughout
» Post and participate in discussions
» Network with other forum members
» Free private messaging
Thread Tools | Display Modes |
#1 |
Uploads: 0
Here is an idea I have to fill my 12' x 12' room that I have available. I would like to build most of this to NTrak standards. I would start with building the reverse modules on the extreme ends so that I could be running while building the rest.
Other than the 2 2' x 4' modules in the center, I have no clue what sizes anything else should be. I also have no clue what kind of trackplans I can incorporate into this. Does anyone have links to some good NTrak trackplans? Or info to help fill in the blanks on my crude little drawing? Does this even look like it will work? I may have to do some adjusting on positioning of modules and whatnot. Depending on sizes.... I think I may have to do away with the upper right corner and put the reverse module there? Anyway.... thanks for looking and any help you can give... ![]() |
#2 |
Uploads: 0
G'man - What do the two blue lines represent?
As an overall shape, looks do-able. It looks like the 2X4 open space in the middle of the top edge isn't needed for access, since you should be able to get to everywhere from the outside. You could maybe put a 2X4 trackless module in there with a big mountain or something, or maybe a divider screen with a backdrop on both sides. Also, couldn't the two modules making the U-turn be combined, or is that an NTrak thing? |
#3 |
Uploads: 0
OOps... the 2' x 4' wasn't actually the space in between.... it was the size of those 2 modules.... Not real sure if there will be space inbetween there or not.
The blue lines were a basic idea for trackwork... not necessarily to be followed exactly.... just something rough for now. |
#4 |
Will always be re-membered
Uploads: 0
Guppyman, go to this link for N trak trackplans and such.
N trak
__________________
Robin To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#5 |
Registered Member
Uploads: 0
#6 |
Inactive Member
Uploads: 0
Very cool to make your Layout to NTRAK standards! Then you could always take it apart and shuffle the pieces and viola you have a new layout!
Do you think you would be up for a trip next year? Why not take a look at this thread:http://www.the-gauge.com/forums/show...&threadid=6966 Looks like you'd be more prepared than any of us! ![]() |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| If I only had the room! | Trainiac77 | HO Scale Model Trains | 3 | 04-19-2007 01:29 PM |
| Room layout idea | xbbox | N / Z Scale Model Trains | 2 | 09-07-2006 10:20 PM |
| Will this be enough room? | ho_scale_rail | N / Z Scale Model Trains | 37 | 08-07-2005 02:24 PM |
| Need Room? | jmarksbery | Scratchin' & Bashin' | 16 | 07-23-2005 10:34 PM |
| Room for one more? | Doc Holliday | HO Scale Model Trains | 5 | 06-08-2004 06:49 PM |
