HobbiesHobby ForumWikiHobby Blogs
Zealot Hobby Forum
Go Back   Zealot Hobby Forum > Trains & Railroads > Tips, Tutorials & Technical > Technical > FAQs
WON'T YOU JOIN US?
You are not a registered member and
are viewing this site as a guest.
Registration is simple and FREE.
Join this CrowdGather community today.
Registration offers the following perks:
» Less advertising throughout
» Post and participate in discussions
» Network with other forum members
» Free private messaging
join
Reply
Thread Tools Display Modes
Old 06-16-2001, 08:23 AM   #1
Woodie
Woodie's Avatar
Uploads: 0
Question Union Pacific M - 32
All,
I found a HO Bachmann Union Pacific M - 32 railmotor, yellow body, grey roof, red decals. (maybe called a doddle bug??) superbly weigthed, and detailed for $35 second hand. I got it because it really resembles the Victorian Railways DERM of the 40's - 60's. (Diesel Electric Rail Motor) Note the arched single window, the side cargo doors, and the side roof ladder together with exhaust etc on the front roof. The UP M - 32 looks similar to these. (actual VR DERMs)
The model in the pic is a kitbashed bachmann "doddle bug" in N scale.
I want to re do the livery into the blue/yellow of the Victorian Railways of the era or Garahbara. However, I cannot get the case off. I don't want to push it too hard in case I break the detailing (steps, handrails, ladders, windshield wipers etc.., or worse, crack the body) Does anyone have one of these, and give me any hints how to get the case off?????
Thanks,
TOOT!
[This message has been edited by Woodie (edited 06-29-2001).]
Woodie is offline   Reply With Quote
Old 06-16-2001, 08:33 AM   #2
Woodie
Woodie's Avatar
Uploads: 0
Talking
This is exactly what I have, except this pic is the N scale model. Mine is HO.
TOOT!
Old 06-16-2001, 03:54 PM   #3
shamus
Registered Member
shamus's Avatar
Uploads: 0
Post
Hi Woodie,
It is a Doodlebug, and if it's the Bachmann one, it has a single large flywheel. Getting the body shell off the chassis is a bit of a pain-in-the-A.. but if you use a couple of knives down the sides, and very gently ease out the sides, you will notice the lugs which hold it in place. Once located, it's easy from there. I have a Doodlebug which I cut down and made it into a Brill.
Shamus
NARA Member #24
http://www.badger-creek.co.uk
shamus is offline   Reply With Quote
Old 06-16-2001, 04:33 PM   #4
Woodie
Woodie's Avatar
Uploads: 0
Thumbs up
Thanks Shamus, Your brilliant. I had found the lugs, but just wasn't prepared to pry the case off hard enough. It seemed to be stuck at the ends, as if i had missed a screw or something. I did end up pullin the drive wheels out of their spring loaded seat, and the drive shaft from the motor,doing all this, but I have managed to get that back in place. Undoing the two screws underneath caused that, as they only hold the motor on, not the case.
Now.... to do or not to do. I just looked this engine up on the web for pricing etc. It's around $300+ AUS (and that's without importing it!) I paid $60 AUS for it. Do I wreck it by giving it my first attempt at painting it into another livery and decals and stuff or not????? It is in perfect unmmarked as new condition.
Shamus, to get the windows unstuck from the inside, just a craft knife razor blade slid underneath to cut the glue contact should do the trick? I dont wanna break them either. Should I leave the handrails/steps/ladder steps, lights, wipers, etc on or try and remove them..... and risk bending breaking them too? Just try tweezers to remove them? Maybe wobble/bend a little to remove them from the lug holes?
Oh well... suppose you gotta learn on something. And a UP yellow googlebop is NOT my prototype for Garahbara!
TOOT!
Old 06-16-2001, 04:38 PM   #5
Woodie
Woodie's Avatar
Uploads: 0
Question
Oh Shamus, By the way, your boglepoop, is it the HO one? and is a Brill just the shorter version?
Yep. Mine is the Bachmann one, with the large single flywheel.
Thanks,
TOOT!
Old 06-17-2001, 04:58 PM   #6
Woodie
Woodie's Avatar
Uploads: 0
Talking
Oh well.... too late now. The UP goggleboop is now a shade of dark blue. Second coat to come. Removed all the windows and as much detailing as possible.
I did break one of the thin window frames on the drivers window, getting the windows out though. Oh well. It stuck to the window, so it should go back when I put the window back. ( I Hope!)
Vicotrian Railways DERM, here we come! Im not going to shorten it though, not quite ready to cut things in half yet!
TOOT!
Old 06-18-2001, 06:04 AM   #7
shamus
Registered Member
shamus's Avatar
Uploads: 0
Post
Hi Woodie,
All my windows came out in one go after I soaked it in warm soapy water.
Yes it is a shortened down Doodlebug, now only 5" long.
cheers
Shamus
NARA Member #24
Old 06-29-2001, 03:05 PM   #8
Woodie
Woodie's Avatar
Uploads: 0
Wink
My "Doodlebug" is now a VIctorian Railway DERM lookalike. Finished it of and it came up really well. Pics of the result are at http://homepages.ihug.com.au/~niceboys/june20011.htm
Photos are not that good, but they get the idea across.
TOOT!
Old 01-25-2008, 02:00 AM   #9
sidewayzinca
Uploads: 0
Default
wow! i just went through my engines from when i stopped mrr when i was around 17yrs old. anyway i found that i had one of these pieces. union pacific livery and i was just wondering how rare this piece is. also, none of these images work anymore so some working ones would be cool.
sidewayzinca is offline   Reply With Quote
Old 01-25-2008, 09:18 AM   #10
MasonJar
It's not rocket surgery
Uploads: 0
Default
Sideways....
Welcome to The Gauge! Unfortunately, I don't think you're going to have much luck with the links/photos in this thread - the last reply before yours was June 2001...!
You might be better off starting a new thread with some pictures of your own to encourage some feedback.
Andrew
__________________
Check out The Gauge's
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Questions? Visit
at The Gauge for all kinds of How-To's
Planning a layout? Try the
form
MasonJar is offline   Reply With Quote
Old 01-25-2008, 04:22 PM   #11
sidewayzinca
Uploads: 0
Default
yeah i did notice that. i figured thats why the links were dead. i'm away from my toys for now so when i get back around them i will take some pictures for everyone.
Old 02-10-2008, 04:42 AM   #12
sidewayzinca
Uploads: 0
Default
here's my model. I'm surprised some pieces didn't get broken after it had been packaged up for so long.
Old 03-03-2008, 11:17 PM   #13
KentBy
GN, NP, SP&S
KentBy's Avatar
Uploads: 0
Default Andrew how long are the pictures saved?
Quote:
Originally Posted by MasonJar View Post
Sideways....
Andrew
I have noticed this when I look back through older posts that the pictures and links don't seem to work. Is there some rule that the Gauge uses for how long it save these for the old posts?
Sideways, I like the doodlebug. I was tracking one on eBay, but the price when higher then I was willing to pay.
It looks like Bachmann is getting ready to release these again with DCC in them. I may just wait until they do. I saw a price of $99.00 on Wholesale trains Your Low Price Hobby Superstore- There's fun for everyone!
Kent
__________________
Kent Byerley
Canby, Oregon
KentBy is offline   Reply With Quote
Old 03-04-2008, 11:59 AM   #14
doctorwayne
Uploads: 0
Default
Quote:
Kent, the reason that the pictures and links in older posts don't usually work is because the Gauge moved to a new server, severing all of the old links and even the pictures that were linked from the old Gauge Gallery.
I rebuilt all of my old photo threads after the move, but I don't think that too many others bothered: it does involve a lot of work.
If you're interested, here's a link to the Thread which contains links to all of my restored Threads.
A fresh update...
Wayne
doctorwayne is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help. Need info about Union Pacific.. IrishMike Getting Started 2 11-11-2007 08:37 PM
Union Pacific is hiring! KCS Getting Started 7 10-30-2006 01:12 AM
Union Pacific Big Boy on Turns UPJunkie HO Scale Model Trains 13 11-25-2004 07:50 AM
Union Pacific arrogance Gary Pfeil Getting Started 9 07-29-2003 02:32 AM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright © 2006 - 2012 Zealot Forums | About Zealot Forums | Advertisers | Investors | Legal | A member of the Crowdgather Forum Community
