» Less advertising throughout
» Post and participate in discussions
» Network with other forum members
» Free private messaging
Thread Tools | Display Modes |
#1 |
Uploads: 0
:P all here r expert. only unfold part and can guess, what is it...yes that is Westland Whirlwind, i know Dr.Zarkov create a great one in 1/72 and 1/32 scale but when i first saw his whirlwind, i promise myself to create mine too. now i can create my whirlwind in 1/48 scale
below is picture of my test build![]() more picture soon...
__________________
Support my work at |
#2 |
Uploads: 0
Looking great as always Nobi. Any chance you might give your hand a try at designing a plane with a clear canopy and a cockpit? Your designs are so seemless that the extra detail a cockpit would add would make them very stunning!
__________________
-Dustin |
#3 |
Uploads: 0
Hi there,
just have a time to final build my model, below is picture of part what color already then all parts of fuselage are finish and wait to glue look closer at nose look closer at tail...i have some problem in coloring state :P i forgot to make shade at last piece of fusleage, i will correct in final kit... ![]() then glue all together more soon ![]()
__________________
#4 |
Uploads: 0
Hi Nobi
Another little work of art, outstanding mate If you can do designs like this with bad eye's, I can't wait for the ones you will do when they are better!! Take care of those eye's Rob |
#5 |
Uploads: 0
Really nice Nobi,
I'm just curious how long it takes you to design a plane like this from nothing to the first test build? Because you sure seem to produce models really quick.
__________________
Will ADD afflicted designer |
#6 |
Uploads: 0
Hi Rob,
My eye is feel better but not turn to normal yet...now i use only right eye to design and build. left eye can see but not help me much on work doctor appoint me to see progress of my eye in end of this month, hope that day my eye is turn to normal ![]() Hi Willja, use assistant from computer program help u can design as fast as u can. study 3Dprogram (i recommend to metaseq for beginner or Rhino3D for advance) and u can design model as u want. i cant tell u how long for design model, it depend on subject and your health :P with my poor eye U-2 took nearly 2 months to release it and when my eye better...Whirlwind come out in 2 weeks but no instruction yet. keep design :P
__________________
#7 |
Uploads: 0
Hi There,
Update picture... look close at nose look closer at tail now add tailwing into look from behind another view more picture soon. PS...just purchase Roman's Wywern and will be build to stand near my whirlwind soon ![]()
__________________
#8 |
Uploads: 0
continue my work today...today i add tail's pod what must make more attention to assemble. then add a canopy into.
canopy add look good so far...:P do u like it?
__________________
#9 |
Uploads: 0
50% finish of my Whirlwind...continue on wing today. wing begin with combine 2 pieces of wings together and make a wing's spar
and glue it together test fitting with no glue yet look closer at seam...Rhino3D did a good job for me. and 2 wing finish then glue it into fuselage engine tomorrow ![]()
__________________
#10 |
Uploads: 0
I wish i can assemble as fast as Rob do :P today i work on engine.
below is a parts of engine before assemble assemble it together then put into wing 2 engines on each wing finish tomorrow will be landing gear, wheel and propeller ![]()
__________________
#11 |
Uploads: 0
Continue work, nearly finish... today is for landing gear...be careful with small parts
main landing gear assemble together glue it into its place landing gear cover ![]() tail landing gear...small parts glue it into its position look closer at tail's landing gear and main landing gear only propeller, bottom's pod and nose's gun left...what r your comments?
__________________
#12 |
Uploads: 0
Finally i finish assemble my Whirlwind. after install propeller and gun...now she is on my shelf
propeller assemble some pod at underneath put gun into FINISH
__________________
#13 |
Uploads: 0
Hi there,
addtion picture of Whirlwind Mk.II from Thaipaperwork
__________________
#14 |
Uploads: 0
NOBI...As always, an easy but beautiful model. Very nice.
__________________
Ashrunner -- a.k.a. Mad Harry Kidd Designer of the world famous line of Flintstone cardmodels which can be found at: To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. And if you like the natural world, check out my Photo Safari albums at: To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
